Author Topic: 1991 1.6 N/A ---> 1984 Jetta  (Read 5830 times)
Reply #15September 24, 2008, 09:51:25 pm
cyrus #1
  • 360
« Reply #15 on: September 24, 2008, 09:51:25 pm »
What is the budget like?  You can send your pump to Giles to have it rebuilt and tweaked.  Most people report noticeably increased power as well as increased mileage.  Talk about win freakin' win.  :twisted:  I think burn_your_money can vouch for this as I'm pretty sure he has an N/A superpump.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #16September 25, 2008, 04:40:29 am
« Reply #16 on: September 25, 2008, 04:40:29 am »
depends on how much it costs for Giles to rebuild the pump.. :P:P
Well ok so there aren't many cheap upgrades.. what are the lowest price upgrades? Pump, Injectors..?
thanks guys.
p.s Dieselweasel where abouts are you in orillia? You've prob seen my car the only mk1 jetta in town, and its half blue and half black.. :P:P
Reply #17September 25, 2008, 09:49:43 am
« Reply #17 on: September 25, 2008, 09:49:43 am »
Quote from: "cyrus #1"
 :D Yes on all counts. LMK if you want a ride in it
The gasser ones might work. I don't know what the temperature ranges are for the senders
Cheap upgrades would be a dual outlet exhaust off a early rabbit, or a scirocco, modifying your air box/tube, tweaking the pump (that could end up expensive though if you turn the wrong screw too far), Getting the injectors rebuilt should be almost at the top of your list of things to do, right after timing belt. A properly finctioning set of injectors will yield better power and economy. And then there is the beautiful mysterious injection pump. $750 for a performance overhaul on the NA, so definitly not cheap, but 100% worth it 8)
Reply #18September 25, 2008, 08:07:14 pm
« Reply #18 on: September 25, 2008, 08:07:14 pm »
HEY GUYS!
Does the motor mount stay on the engine from the diesel and bolt to the frame of my car in the same spot? because they are definetly different front mounts... thought it was a drop in job??
Well i dunno the car to me is def worth 450.. we decided on an extra 50 bucks for a rad, alt, and starter.. plus a bunch of other stuff thats gonna come with... he ditched it in nov. 2006 started for the first time today.. first crank!! WOOT
What exactly needs to be done in the order of actually swapping??  like do the mounts realllllllllllly line up?
Reply #19September 26, 2008, 05:14:09 pm
« Reply #19 on: September 26, 2008, 05:14:09 pm »
All of your mk1 mounts are the same, except the passanger side diesel one. That needs to be a mk1 diesel mount.
You should really replace all the mounts while they are out.
Reply #20September 26, 2008, 08:31:38 pm
« Reply #20 on: September 26, 2008, 08:31:38 pm »
the dude replaced them all before he crashed it.. they have like 3000 on them tops.. are they still ok? if not then i will look in to new ones.. but i would like to reuse as much as possible you know?
Reply #21September 26, 2008, 10:03:03 pm
cyrus #1
  • 360
« Reply #21 on: September 26, 2008, 10:03:03 pm »
You should have no worries if they only have 3000 km's on them, provided they weren't damaged when he crashed it.  300,000 is a different story.   :D
Cody
2002 Jetta TDI
Reply #22September 27, 2008, 12:30:03 am
« Reply #22 on: September 27, 2008, 12:30:03 am »
well i dont kno much about mounts :P But they werent broken or anything.. he engine has tilted back a bit in th bay because the front end of the car is bent upwards from the ditch..
So i really dunnnnno :P
Reply #23September 27, 2008, 06:35:55 am
« Reply #23 on: September 27, 2008, 06:35:55 am »
You can't use those mounts, you need to use the mk1 motor mounts on the gasser
Reply #24September 27, 2008, 08:14:15 am
« Reply #24 on: September 27, 2008, 08:14:15 am »
Quote from: "burn_your_money"
I need to use the motor mounts of my engine now? off my 1.7 gasser? except the mk1 diesel one i IM you about on the Tex??
Reply #25September 27, 2008, 01:27:32 pm
« Reply #25 on: September 27, 2008, 01:27:32 pm »
correct
Reply #26September 27, 2008, 07:14:37 pm
« Reply #26 on: September 27, 2008, 07:14:37 pm »
cheap EGT monitoring!?
What would be the best to monitor EGT's? cheapo wise.. lol Im all up for being able to monitor them, and i plan on doing the simple mods that will alow me to reach 1400 degrees but rarely use it.... just to be able too id rather have the MPG then performance you know?
Can i do all the small free mods, and not use them? most of them are WOT enhancements arent they??
