Author Topic: Metal head gasket on solid 1.6 head  (Read 4078 times)
September 09, 2008, 07:39:30 pm
gilligan5000
  • 63
« on: September 09, 2008, 07:39:30 pm »
Ok, I know I've seen it before, but I have searched way too long for and am coming up short here.
1. Where the hell can I get a metal head casket in the US?!?!
2. What are people using to block the illusive extra hole in the aaz gasket?
Thanks
Reply #1September 09, 2008, 07:53:39 pm
« Reply #1 on: September 09, 2008, 07:53:39 pm »
I think that you can get the head gasket from MykeW the moderator on here or autohaus...
This has been discussed on here some, I would do a search for frankenmotor or 1.9L metal head gasket fix, or wait and see if someone will respond fast enough for you.
Hope I could help.
Reply #2September 10, 2008, 07:38:40 am
Re: Metal head gasket on solid 1.6 head
« Reply #2 on: September 10, 2008, 07:38:40 am »
Quote from: "gilligan5000"
Thanks
Click on the link in my sig.
There are other ways but thus far I have zero leaks of anykind.
Reply #3September 10, 2008, 10:51:04 am
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: September 10, 2008, 10:51:04 am »
I don't understand why people don't use 1.9 TDI head gaskets?
I have one in my hydro 1.6 TD and it works fine...
the notchest are the same and everything
Reply #4September 10, 2008, 11:24:24 am
« Reply #4 on: September 10, 2008, 11:24:24 am »
Quote from: "Smokey Eddy"
i think that is just it... that the new AAZ are just like the TDI (1Z/AHU)... if anyone cares to confirm the p/n's  :wink:
Reply #5September 10, 2008, 12:21:06 pm
MJF
  • 581
« Reply #5 on: September 10, 2008, 12:21:06 pm »
TDI does not have prechambers.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #6September 10, 2008, 12:24:17 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #6 on: September 10, 2008, 12:24:17 pm »
Exactly. The TDI head gasket will NOT work on an IDI. Only the AAZ unit will. Part numbers are different.
Reply #7September 10, 2008, 01:14:22 pm
myke_w
  • 1099
« Reply #7 on: September 10, 2008, 01:14:22 pm »
Part number are different as mentioned.
Here's as pic of an AAZ one for reference
Reply #8September 10, 2008, 01:14:29 pm
  • 3468
« Reply #8 on: September 10, 2008, 01:14:29 pm »
Then why does it work on my 1.6l IDI?
I got a 1.9 TDI gasket. I'm sure of it... i asked to look at one, and its metal, it does however look like that picture there
My car is currently using it...i drove it today
Reply #9September 10, 2008, 01:16:40 pm
  • 3468
« Reply #9 on: September 10, 2008, 01:16:40 pm »
I am really confused...
I compared the 1.6 HG and the 1.9 HG at my vw import shop in Abbotsford and they were identical.... completely identical...
no holes covered, no extra holes, same bore
maybe i actually got an aaz HG?
I didnt do any modifications to anything for it i just threw it on there and torqued it down
Reply #10September 10, 2008, 01:23:50 pm
« Reply #10 on: September 10, 2008, 01:23:50 pm »
The one Myke posted a pic of IS the 1.9 AAZ gasket.
The TDI 1.9 is different.
Reply #11September 10, 2008, 01:27:42 pm
  • 3468
« Reply #11 on: September 10, 2008, 01:27:42 pm »
ahhhh i DID get an aaz then
Reply #12September 10, 2008, 01:35:27 pm
myke_w
  • 1099
« Reply #12 on: September 10, 2008, 01:35:27 pm »
the AAZ one definitely has reinforcements for the Prechambers
here's a shot of an AHU / 1Z gasket for reference
Reply #13September 10, 2008, 01:41:40 pm
  • 3468
« Reply #13 on: September 10, 2008, 01:41:40 pm »
Hmmm the AAZ has an extra hole on the bottom right
what else is different?
Reply #14September 10, 2008, 01:48:06 pm
myke_w
  • 1099
« Reply #14 on: September 10, 2008, 01:48:06 pm »
Quote from: "myke_w"
