Author Topic: Switching Oil?  (Read 4155 times)
Reply #15September 12, 2008, 05:47:02 am
arb
Switching Oil?
« Reply #15 on: September 12, 2008, 05:47:02 am »
Yes, I really meant 100,000 miles. Mobil says WITH analysis AND filter changes, you can go indeffinately. I was paying $80 for the 4 gallon case it comes in ( 1 gal jugs is the smallest unit they sell in - 55 gal drums is the most common) So, today you're looking at about $28 per gallon. This is still a very good deal IF you go extended run.
I used Titian Labs - it was sold at K-Mart for about $12 a test.
http://www.titanlab.com/  You can order it directly from them, maybe some pro auto parts stores.
Both PowerStrokes are still running strong, but I don't have them.
Reply #16September 12, 2008, 10:04:02 am
Switching Oil?
« Reply #16 on: September 12, 2008, 10:04:02 am »
5w40 should be fine... 0w40 would be for -30C or so.
although if your car doesn't burn/leak oil, then 0w40 would be better since it would go to where it is needed the most a lot quicker.
Reply #17September 13, 2008, 12:12:16 pm
Ziptar
  • 565
Switching Oil?
« Reply #17 on: September 13, 2008, 12:12:16 pm »
Quote from: "jtanguay"
Thanks! it doesn't leak or burn oil so maybe I'll try it.
