Author Topic: Started my port and polish today!! lots of pics!  (Read 4942 times)
August 22, 2008, 09:48:55 pm
53 willys
« on: August 22, 2008, 09:48:55 pm »
So I started to P&P my 1.6td head today :twisted:
I gasket matched the intake and exhaust and also the exhaust manifold.
I bought a $15 package of 80grit and 120 grit tapered and straight sanding barrels from harbor freight man they worked really good!!!
I know lots of guys say not to do the exhust but when I looked at the ports they are not very flow freindly at ALL...most the restriction is around the valve seat..I am half way done now..I planned to do a VERY light P&P but once I was in there I could not help but remove all the sharp edges and casting seams...I got some pics I will post in the morning. 8)
Reply #1August 23, 2008, 08:29:11 am
g-spec
  • 289
« Reply #1 on: August 23, 2008, 08:29:11 am »
I did the same thing to my 1.9AAZ head while I was rebuilding the head. I also matched the exhaust manifold to the gasket and the intake manifold.
Reply #2August 23, 2008, 06:40:40 pm
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: August 23, 2008, 06:40:40 pm »
wow get those pics up boys i want to see
Reply #3August 23, 2008, 07:32:08 pm
53 willys
« Reply #3 on: August 23, 2008, 07:32:08 pm »
Quote from: "Smokey Eddy"
man I have took like 50 pics and only 10 are maybe worth posting...I am having a hard time getting them right.....I do have the pics..but I am at work and cant get access to my photobucket account anymore..so I will post them in the AM 8)
Reply #4August 24, 2008, 12:05:10 am
53 willys
« Reply #4 on: August 24, 2008, 12:05:10 am »
here they are...I did not remove the valve guides..I just could not see it making that much difference when the guide sticks so far out of the head casting...but you can see the ridge that is big and sharp on the valve side....I did not remove to much in the ports..mostly just cleaned and smoothed all the edges...this is pics with only half the work done..I wanted to try and get a before/side by side shot for reference.
Reply #5August 24, 2008, 12:12:12 am
53 willys
« Reply #5 on: August 24, 2008, 12:12:12 am »
some more showing the seam...
I like this pic you can see the ridge has been taken down and you can tell there is much more room....left intake port=stock....right intake port has been ported an polished.
Harbor freight sanding barrels
sorry for the blurry pics I tried many different shots..I'm no photographer!
this is my shaving pile after doing half the head...lol
it's easier to tell what and how much better the head is when you can run your finger across the smoothed ports vs stock..but like I said it was hard for me to capture that with the camera..
it also hard to tell but everything was gasket matched too.
Reply #6August 24, 2008, 01:24:49 am
  • 3468
« Reply #6 on: August 24, 2008, 01:24:49 am »
naw naww
looks awesome man
i wish i had a head worth doing that to
Reply #7December 06, 2010, 09:59:02 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
Re: Started my port and polish today!! lots of pics!
« Reply #7 on: December 06, 2010, 09:59:02 am »
Really looks good man! Im getting ready to do my head. did you do all of it with those barrels or did you polish it with something else?
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #8December 06, 2010, 10:06:17 am
rallydiesel
  • 1880
« Reply #8 on: December 06, 2010, 10:06:17 am »
Looks good!
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #9December 06, 2010, 10:48:00 am
« Reply #9 on: December 06, 2010, 10:48:00 am »
Holy old thread Batman!!!!!!
Last post was Aug of 2008
Reply #10December 06, 2010, 12:41:54 pm
« Reply #10 on: December 06, 2010, 12:41:54 pm »
I did a 8 year thread bump on thevortex last week :o lol they responded too!! Lol
Reply #11December 06, 2010, 05:33:23 pm
Thezorn
  • 381
« Reply #11 on: December 06, 2010, 05:33:23 pm »
Haha just in time for me actually, probabley going to be doing this sometime this week.
Compounded 93 AAZ
Reply #12December 06, 2010, 06:21:18 pm
dankcorey22
  • 379
    Cummins!
« Reply #12 on: December 06, 2010, 06:21:18 pm »
Me too! Ill probably post some pic.
