Author Topic: whats the best turbo for a tdi?  (Read 3097 times)
August 06, 2008, 11:03:04 am
oldskool rich
  • 446
« on: August 06, 2008, 11:03:04 am »
i want to flow as much air as possible, 35psi, no/little lag, must be super reliable and wait for it.... cheap
whats best value for money?
i think VNT is out of the question for reliability and drivability, looking at ball bearing turbos such as  garrett T28, anyone tried these? anyone know of a good turbo? my T3 its pure toss :(
f6squared I.D.S.T
Reply #1August 06, 2008, 12:06:28 pm
gigaz2
  • 626
Re: whats the best turbo for a tdi?
« Reply #1 on: August 06, 2008, 12:06:28 pm »
Quote from: "oldskool rich"
why do you say that? the only damaged vnts I've seen were the one that were being run way past they're specs, or oil starvation/coke from shutting down immediately after a hard run.
from those demands, you are probably interested in a compound setup, two "cheap" turbos instead of an ultra special one.
Reply #2August 06, 2008, 08:46:26 pm
« Reply #2 on: August 06, 2008, 08:46:26 pm »
yea i'd personally go with a nice big VNT.  as mentioned in previous posts, the main reason the VNT's are dying is because they are directly matched to the engines output, and not over-engineered.  just get a nice big one and off you go.
if you have the money to spend on a ball bearing turbo, go that route.  it will spool as fast if not faster than the VNT's. $$$$$ though!
