Author Topic: Bad axle (WHICH ONE??)  (Read 11018 times)
Reply #15August 16, 2008, 04:43:16 pm
Sandy
  • 31
« Reply #15 on: August 16, 2008, 04:43:16 pm »
CoolAirVw ; That is another problem I face. The OE inner joint and shaft (one piece) is over $500 and to install a used one might open up a whole different can of worms. The aftermarket complete axle (new china) is $80 but that could lead me astray.
And on top of all this I'm only looking for a short time fix. In time I'm going to convert this car to a TDI 5sp. At that time I wouldn't need those $500 tripode joints as they didn't come with the 5sp transmission.
2  99 A3 JETTA WOLFSBURG'S
    (RUST FREE FROM FL)
98 JETTA TDI...BUILT NOT BOUGHT
    (RUST FREE FROM FL)
Reply #16August 16, 2008, 06:16:19 pm
« Reply #16 on: August 16, 2008, 06:16:19 pm »
Quote from: "Sandy"
if you're going to change to 5spd then go with the chinese ones.
Reply #17August 17, 2008, 04:55:23 pm
Sandy
  • 31
« Reply #17 on: August 17, 2008, 04:55:23 pm »
Just an update; I removed the right side axle today and found quite a bit of play in the inside joint that I couldn't feel as well when it was connected to the wheel and transmission. I opted for the (new china) $80 axle as a short time fix. I road tested the car and no shimmy.  :D  :D I guess "TIME" will be the real test.
Thanks to all that voiced an opinion.
    (RUST FREE FROM FL)
    (RUST FREE FROM FL)
Reply #18August 19, 2008, 05:25:54 am
CoolAirVw
  • 175
« Reply #18 on: August 19, 2008, 05:25:54 am »
Quote from: "Sandy"
......found quite a bit of play in the inside joint that I couldn't feel as well when it was connected to the wheel and transmission.
So the wiggle test is the best way (but not a perfect way) to tell which side is bad, you can take it to the bank.
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
