Author Topic: Mercedes Nozzles  (Read 5805 times)
Reply #15July 09, 2008, 11:22:23 am
Mercedes Nozzles
« Reply #15 on: July 09, 2008, 11:22:23 am »
Quote from: "VW_Commuter"
Zuk, do you have the part/stock number for those nozzles for the CASE backhoe?
Yes I do, at home.
I think i even have the flow rates.
I'll post them up tonight. You may have to drop me a PM to remind me though. Once I get home I shut down all brain activity..
Reply #16July 09, 2008, 12:11:56 pm
Mercedes Nozzles
« Reply #16 on: July 09, 2008, 12:11:56 pm »
Quote from: "zukgod1"
OMG OMG OMG... flow rates !!  ;-)
I'd kill to see some flow rates !!
Reply #17July 09, 2008, 12:50:30 pm
Mercedes Nozzles
« Reply #17 on: July 09, 2008, 12:50:30 pm »
Quote from: "libbybapa"
X2 part number and flow rates needed.   :wink:
Andrew
I have both the part #'s and flow rates for the CASE tips and Chev 6.5 tips.
Reply #18July 09, 2008, 02:05:15 pm
dillenger1
  • 777
Mercedes Nozzles
« Reply #18 on: July 09, 2008, 02:05:15 pm »
.........aaaaaaaaand...?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #19July 09, 2008, 02:12:30 pm
Mercedes Nozzles
« Reply #19 on: July 09, 2008, 02:12:30 pm »
Patience grasshoppa. I'm not home and that's where the info is located.
I'm still @ work for a few hrs
Reply #20July 10, 2008, 06:17:07 am
Mercedes Nozzles
« Reply #20 on: July 10, 2008, 06:17:07 am »
Here's what I have guys.
mm/1000st        Application       Part#
76  Yellow dot= 6.2L Nozzel     DNSO SD 248
76  White dot=    VW              DNSO SD 293
80  Red dot=       CASE          DN4S D42
The first # is the flow rate it has a mm/3, 1000st (I have no idea what that means)
So for what it worth hope it helps.
Reply #21July 10, 2008, 06:21:28 am
gigaz2
  • 626
Mercedes Nozzles
« Reply #21 on: July 10, 2008, 06:21:28 am »
cubic millimeters for 1000 strokes? makes sense to me
Reply #22July 10, 2008, 06:28:46 am
Mercedes Nozzles
« Reply #22 on: July 10, 2008, 06:28:46 am »
As long as someone knows what it means :)
