Author Topic: where to mount oil pressure sender?  (Read 2159 times)
July 01, 2008, 07:27:48 am
Dirtrag2
  • 298
« on: July 01, 2008, 07:27:48 am »
Hi, i have an autometer oil pressure gauge and sender unit and the instructions call for a remote mounting in high vibration apps.  Should i mount it remotely on the firewall or can i mount it direclty on the top sender hole in the head ?
edit: BTW its a AAZ engine  :oops:
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #1July 01, 2008, 09:28:49 am
« Reply #1 on: July 01, 2008, 09:28:49 am »
I put mine on the oil filter flange and have had no problems.
Reply #2July 01, 2008, 10:28:44 am
« Reply #2 on: July 01, 2008, 10:28:44 am »
Quote from: "jimfoo"
I put mine on the head (not AAZ though)
I figure I wanted to see what the engine was seeing and I didn't feel that a filter mounted gauge was the best option.
Not bashing jimfoo at all just for me I wanted to see the end result.
It may be interesting to move it there on my engine to see what if any difference there is.. Maybe I will..
Reply #3July 01, 2008, 04:00:59 pm
Dirtrag2
  • 298
« Reply #3 on: July 01, 2008, 04:00:59 pm »
thanks's Jim
on either location the pressure should be the same, no?
...Darcy
Reply #4July 01, 2008, 10:15:42 pm
« Reply #4 on: July 01, 2008, 10:15:42 pm »
Yes and no.
On the filter housing the oil has only gone through the IM bearing I think, in the head it has the cam bearings as well..
