Author Topic: turbos and down pipes  (Read 24287 times)
Reply #45August 09, 2005, 12:22:10 am
Maarten
  • 339
« Reply #45 on: August 09, 2005, 12:22:10 am »
Why would the turbo need backpressure? just see it as a big fan that you blow onto, does it spin faster when you block the airflow behind the fan?
I don't think so.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #46August 11, 2005, 03:19:42 am
Caddy-Daddy
  • 36
    • http://www.caddy-clan.nl
« Reply #46 on: August 11, 2005, 03:19:42 am »
Nice one mate !!!.. Can't wait till mine is finished..  :D  :D
Caddy's Rule
Reply #47August 11, 2005, 07:39:25 pm
rackley
  • 96
« Reply #47 on: August 11, 2005, 07:39:25 pm »
It's the same principal as turbo gas motors.  I have a turbo 1.8L miata and a 2.5" is better than a 3.0".  The reason it's better isn't because it makes more power - it's because you don't get any power gain going to 3.0.  So the 2.5 is the same power, plus it's cheaper to make, it's easier to fit and less likely to bang on things.
www.vocontrol.com
VO Control - Programmable VegOil and WVO Controllers
Reply #48September 20, 2005, 12:53:01 pm
Maarten
  • 339
« Reply #48 on: September 20, 2005, 12:53:01 pm »
With a little modification the KKK K24 with DP fits onto intakemanifold, tight but it fits :D
Clearance for the gearmechanism is ok too but I need to wait a few days for the oilretour adapter to arrive.. So tomorrow I can go on with welding a custom exhaust (60mm, no silencers) and I hope to fly.. euh drive this weekend  8)
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
