Author Topic: 1.9 TD/i Question?  (Read 5104 times)
Reply #15June 04, 2008, 05:00:25 pm
1.9 TD/i Question?
« Reply #15 on: June 04, 2008, 05:00:25 pm »
Quote from: "gigaz2"
look closer, its a tdi block AND head
aha... didn't check the photo's.. maybe he should change his sig  :wink:
Reply #16June 05, 2008, 02:43:27 am
ThomZe
  • 57
Ow
« Reply #16 on: June 05, 2008, 02:43:27 am »
I'm sorry if I said something wrong, only know what the former owner told me.. ?
But that will say, it's a complete TDI "Mechanical" not ECU controlled engine? Then it's just badly configurated since it runs so bad?
BMW E36 320i Automatic
Reply #17June 05, 2008, 03:06:53 am
gigaz2
  • 626
1.9 TD/i Question?
« Reply #17 on: June 05, 2008, 03:06:53 am »
I believe so, in my country we also see a few cases of adventurous guys that just bolt things together and hope they work as a whole.
but TDI is a different technology, and without taking you IP apart (or asking the previous owner) we can only guess what is inside.
if he did a good job, the lack of performance could come from something different.
Reply #18June 05, 2008, 04:31:01 am
ThomZe
  • 57
Hmm
« Reply #18 on: June 05, 2008, 04:31:01 am »
Okay, well to bad, I'm to inexperienced to do anything to it, better try to sell it again, but thanks :)
Reply #19June 05, 2008, 05:21:40 am
ThomZe
  • 57
ow
« Reply #19 on: June 05, 2008, 05:21:40 am »
By the way, could the performance issue be, because of the pump timing? By searching the net a little I found out others with m-tdi pumps had powerloss due to bad pump timing, it should be more advanced? more aggressive?
Reply #20June 05, 2008, 06:11:24 am
saurkraut
  • 904
Re: ow
« Reply #20 on: June 05, 2008, 06:11:24 am »
Quote from: "ThomZe"
Your timing needs to be right, with the right pump.  You have the wrong pump on your engine.  "Aggressive" has nothing to do with it.
Read the link that jtanquay provided.  It talks about the pump you need:
 http://www.vwdiesel.net/phpBB/viewtopic.php?t=12912
Then go to the proper page on this forum and identify your engine as an MTDi:
http://vwdiesel.net/phpBB/viewforum.php?f=5
And ask for the proper timing spec for an MTDi.
There also may be some one that has a spec for running your engine with the wrong pump (the one you have) and achieving acceptable results.
Also, as Jimfoo pointed out, you need a bigger exhaust system, from the turbo, all the way to the point that it exits the car.  2.5 inch / 64mm would be a minimum.  Muffler is optional.
MTDi engines have been done many times befor.  The is pleanty of information available on how to do this right.
If this is beyond your capabilty, motivation, or means, sell the car and disclose that it has the wrong pump, and give the new owner the information to make it right.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
