Author Topic: rebuilt head going on  (Read 11268 times)
Reply #15May 28, 2008, 08:57:19 am
« Reply #15 on: May 28, 2008, 08:57:19 am »
Keep the cam sprocket ever so slightly loose, tighten the belt, set the engine and cam at TDC, tighten cam sprocket bolt. Check belt tension and loosen slightly if required.
Reply #16May 28, 2008, 09:49:59 am
subsonic
  • 1836
« Reply #16 on: May 28, 2008, 09:49:59 am »
Well, I did all that except backing off the tension.  If I back off the tension, I can twist more than the 45 degrees.  I called parts place and the guy on the phone told me if the timing mark was off just a little bit it was ok.  It is probably off a little less than 1/2 cm.  I may try and run it like that.
On to IP timing.  I set the cold start all the way off.  Set the engine to TDC(within 1/2 cm :( ) , installed my dial gauge with 2.5 of preload.  Turned engine counter clockwise until the needle stopped moving.  Set the dial face to "0".  Turned the engine clockwise while watching the gauge until TDC.  No movement.  Did it twice just to make sure nothing was binding on the gauge.  So it looks like I need to move my pump.  Since I am at 0,  I will need to move the pump so the needle swings clockwise to the correct setting, yes?  .90--1.05mm.
Reply #17May 28, 2008, 10:35:09 am
« Reply #17 on: May 28, 2008, 10:35:09 am »
You should have had some movement. When you zeroed it, you did just turn the face and not actually slide the dial indicator out right?
Reply #18May 28, 2008, 11:54:46 am
subsonic
  • 1836
« Reply #18 on: May 28, 2008, 11:54:46 am »
yeah.  The timing is getting to be a pain in the ass.  I found out if I use the clamping screw on the part that screws onto the pump, and actually holds the dial gauge with the extension piece, it locks up the gauge.  I think the bore that gauge slides into is a bit too large.
I finally got it to lock in place with out restricting movement.  It is a 0-10mm gauge.  I set preload to 5mm(per Giles).
   Turned the engine counter clockwise.  The reading went up, and then dropped as I turned the crank.  I turned until all movement on the dial gauge stopped.  I even went 1/4 turn more to make sure I had no more movement.  I then set the gauge to 0 and turned clockwise.  The needle moved for a second and stopped, I continued to turn clockwise and the needle started to move again.  My final reading at TDC was 2.15  Two complete revolutions plus 15.  I am going to try to loosen the IP bolts and adjust it to .95
Reply #19May 28, 2008, 03:09:48 pm
subsonic
  • 1836
« Reply #19 on: May 28, 2008, 03:09:48 pm »
Well I redid the timing a few more times.  I think I finally did it correctly.  When I spun the engine forward I ended up at .37 .  I loosened up the IP and pushed it in towards the block until I was at .95 . Everything looks right. Reset all the line connections at the injectors and the pump. I am going to start putting everything else together now.  The crankshaft and water pump pulleys still need to go back on with new belts.  I need to adjust the tension on the A/C and then the Alt.
Jeeez the first time you do this it sure takes a long time.
Reply #20May 28, 2008, 06:48:37 pm
subsonic
  • 1836
« Reply #20 on: May 28, 2008, 06:48:37 pm »
Got the pulleys on, and the lower cover.  How the hell do you hold the water pump pulley while you tighten the bolts?  I ended up just gripping it by hand and turning the bolts until i couldnt hold it any more.  Gotta get em tighter then that before I fire it up.  New belts are on.  Big difference in the amount of stretch between the old A/C Waterpump belt and the new one.  Old one did not look bad, but the new one is the same size and it is much tighter.  I will get the Alt installed in the morning.  I am going to leave the top timing belt cover off for now, just to make sure everything is tracking correctly.  Put the valve cover back on, stick the dip stick tube back in, add some oil and coolant and we'll see if I did this correctly.
Reply #21May 28, 2008, 06:52:31 pm
subsonic
  • 1836
« Reply #21 on: May 28, 2008, 06:52:31 pm »
Quote from: "subsonic"
I am having a problem with the timing belt.  I have the Injection pump pulley locked in the correct location, the cam is locked at TDC, The flywheel mark is sitting directly under the TDC mark arrow, verified as correct while the head was off.  When I set the belt tensioner to the correct tension, the mark on the flywheel moves either to the left or right, depending on which way I move the tensioner while adjusting it.  It's not off by a lot,  1/2 a cm approx.  I have pulled the belt off and adjusted it 3 times, I get the same thing everytime.   Suggestions?
Solved the problem.  Talked to Giles.  He told me to pull the IP locking pin before I tensioned the belt so the tension would be distributed evenly.  I did and the timing mark stayed spot on.   By the way, I had the cam pulley bolt loose while I did this.
Reply #22May 29, 2008, 12:45:37 pm
subsonic
  • 1836
« Reply #22 on: May 29, 2008, 12:45:37 pm »
IT LIVES!!!!!! :lol:
Got it all together except the exhaust pipe.  Still need to attach it to the manifold.  The old boy fired right up after a couple cranking sessions.  If it wasnt for the fact that the exhaust currently ends at the exhaust manifold, I would say it sounds much better :lol:   I was really worried about the timing belt tracking true on the IP pump pulley.  When I turned it by hand when it was going together, it walked right up to the edge of the pulley.  I was afraid that when I ran it it would keep on a walkin.  It appears to be staying put for now.  I have only run it for about 5 min, but no movement.
I am going to put the car up on jacks and attach the exhaust system to the manifold.  Here is my question.  Is it possible to use normal jackstands under the car?  If I Jack on the lift point, where do I put the jack stand?  Do I need special adapters to go on the jackstands of something?
Reply #23May 29, 2008, 04:27:17 pm
« Reply #23 on: May 29, 2008, 04:27:17 pm »
Congrats!
Reply #24May 29, 2008, 04:30:14 pm
« Reply #24 on: May 29, 2008, 04:30:14 pm »
Glad to hear you got it running. I heard Giles explaining the timing proceedure to you on the phone.
Put the jackstand under the subframe. The part that the steering rack is attached to, and the rear engine and tranny mount. I like to put them out as far as possible for stability.
Reply #25May 29, 2008, 04:49:03 pm
subsonic
  • 1836
« Reply #25 on: May 29, 2008, 04:49:03 pm »
Yeah, I was screwing up the timing bit a few times.  Finally got it.  Came out to 37 and I bumped it up to the recomended .95.  I do have a small lift pump attached after the filter, I wonder if that makes a difference in the timing?
Reply #26May 29, 2008, 04:58:10 pm
« Reply #26 on: May 29, 2008, 04:58:10 pm »
It will effect the dynamic timing depending on what it is rated at PSI wise.
I remeber my first time doing timing... I had done a headgasket job, it was hellish.
Reply #27May 29, 2008, 06:36:26 pm
subsonic
  • 1836
« Reply #27 on: May 29, 2008, 06:36:26 pm »
Quote from: "burn_your_money"
Thanks guys,
I wont lie, I was pretty freakin pissed when I kept doing it wrong and coming up with odd ball readings, or the dial gauge would slip out as I was making the final adjustment,  or I would do it and get nothing because the locking pin was binding the gauge etc etc..  I felt like a knothead calling Giles over and over again, " Wow, thats pretty far off Jim."
Next to the last time before I got it right, I remember saying to myself, I have done all the hard work, I have AAA, I'm getting this pos towed to a garage and have them do it!  I'm glad i didnt.    By the way I snapped the part of the vacume pump line that goes in next to the brake resevoir when I took it off to make room for the gauge :evil:   What a pain in the ass that was to fix.  I had to pull out the end that plugs into the brake booster and hog it out with a drill bit by hand, same deal with the end of the line.  Of course the drill bit I had was a tad too small so I had to work it in at a angle to get all the material out.  I then had to go digging aroound in the garage because somewhere on my shelfs I knew I had a left over piece of small gauge bendable copper pipe.  Took like an hour to find.  6" left, plenty.  I cut it to length and went to mate the two ends of the vacume line.  One end fit great, no joy on the other end.  I had to spin the stupid piece of copper by hand while holding sand paper around it so I could get it to fit.    Talk about jerry rigged.  Slapped some permatex around the ends for a good seal and mashed them together.  That joints not breaking again.
The last part that I will share is how I stripped one of the IP mounting bolt hole while putting in the bolts.  No problem at all.  whip out the tap and die set, lets see the old hole was 8mm, I will just bump it up to the next size, 9mm.  Ever try and buy a 9mm bolt at a hardware store?  They just look at you like you are retarded.  "Um.....sorry, 6mm, 8mm ,and 10mm no problem, good luck finding a 9mm."  " Why not make it a 10mm?"   Because the damn bolt will now be cutting into the sides of the slot on the IP bracket you simpleton!!! :roll:
Of course what really happened was I stood there looking at them and said " Aw ***, that's just great :x "
So my IP pump only has 3 bolts holding it in place right now, but thats   way better then what I started with. :lol:
I will try and find out what the lift pump puts out Tyler, since you now are working at Giles shop (lucky bastard-little nepotism goin on there? :wink: ) perhaps you can ask if I should adjust the timing to compensate.      Of course......I may wait a week or so before I mess with it again :wink:
Reply #28May 30, 2008, 11:52:45 am
subsonic
  • 1836
« Reply #28 on: May 30, 2008, 11:52:45 am »
Took it for a test spin, runs good, less smoke. Park it in the driveway, huge puddle of oil under it.  It is just running out the dipstick hole in the block.  I mean it's coming out good.  Perhaps the gasket stuff I used was not the right stuff.  I think I need to find an o-ring or something to put in there, and then some gasket crap.  Popped the oil cap and there was puffs of white smoke coming out.  I am sure the rings are worn.  Hell I put 20-50 in it.  Sure would be nice to have my new engine instead of chasing this one.
Reply #29May 30, 2008, 09:01:08 pm
subsonic
  • 1836
« Reply #29 on: May 30, 2008, 09:01:08 pm »
Dead on the side of the road :evil:
