Author Topic: WANTED - 1.6 TD boost PIN  (Read 4352 times)
May 13, 2008, 03:25:40 pm
blackdogvan
  • 574
« on: May 13, 2008, 03:25:40 pm »
Looking for a 1.6l boost pin to upgrade my 1.9l AAZ.
thanks!!!!
1991 Vanagon 1.9 mTDI
Reply #1May 13, 2008, 06:26:45 pm
« Reply #1 on: May 13, 2008, 06:26:45 pm »
You can use a Cummins pin as well. just be sure to use the 1.6 or Cummins spring with the pin. On the Cummins spring, I had to open the bottom up just a little so it would fit over the spring retainer.
Reply #2May 14, 2008, 09:30:27 am
blackdogvan
  • 574
« Reply #2 on: May 14, 2008, 09:30:27 am »
Anyone have a link to a post with the Part number? (or just the #?) Cummins parts are easy for me to find, Rover TD parts, not so much.
Reply #3May 14, 2008, 10:34:40 am
« Reply #3 on: May 14, 2008, 10:34:40 am »
I didn't get a #, just bought a pin and spring from the local rebuilder. Whatever it was he had on hand. I don't imagine there aren't too many stock variations
Reply #4May 14, 2008, 11:17:56 am
RabbitGTDguy
  • 1274
« Reply #4 on: May 14, 2008, 11:17:56 am »
Jim,
I am surprised that a stock Cummins pin just fit in your LDA on the 1.6 pump...
My cummins pump in order to utilize the stock cummins pin in the VW LDA required disassembly of the LDA and removal of the stock boost pin sleeve and swapping in the Cummins sleeve as well (as the diameter of the cummins pin is slightly larger in my case). Maybe the stock AAZ pump runs this "large" sleeve for the boost pin?
Joe
1972 VW Westfalia
2001 Audi TT 225 Quattro Roadster (something newer :) )
Reply #5May 14, 2008, 02:01:55 pm
« Reply #5 on: May 14, 2008, 02:01:55 pm »
I don't have a 1.6, I have an AAZ, um I mean M-TDI.
