Author Topic: overheating TD Vanagon  (Read 7841 times)
Reply #15May 01, 2008, 12:38:04 pm
witoke
  • 76
« Reply #15 on: May 01, 2008, 12:38:04 pm »
Okay, boost gauge fitted. Tested with the BOV untouched and I could get max 10 psi. Disabled the BOV with a bolt per previous threads and went for a drive. Maxed out at 10psi. So whatever it was it was not my BOV holding things up.
Now I thought I understood that the way to get more boost was to add more fuel. But if I add fuel will that not just create boost in proportion to the fuel increase and so not solve my EGT problem? Or is there some other way to add boost?
I will use the "Search" and try to find that answer as well as the answer to how to test the operation of the waste-gate.
Reply #16May 01, 2008, 01:19:00 pm
« Reply #16 on: May 01, 2008, 01:19:00 pm »
The wastegate is probably working as 10 psi is a fairly normal stock setting. You will need to find out how to adjust it for your particular turbo to increase the boost. It will probably entail turning in a screw on the actuator.
Reply #17May 01, 2008, 01:23:43 pm
« Reply #17 on: May 01, 2008, 01:23:43 pm »
Quote from: "jimfoo"
1x.  if the BOV was regulating boost, you would hit 12-13 psi, then a big surge in power, boost would drop to about 4-5 psi, and then it would close and boost would rise from there.  wastegate hits 10 psi, and regulates boost pressure quite smoothly and reliably.  you can also try using a manual boost controller, as it just 'tricks' the wastegate into thinking the turbo has not yet achieved the correct pressure, so it stays closed longer (depending on the setting)
Reply #18May 01, 2008, 04:42:36 pm
witoke
  • 76
« Reply #18 on: May 01, 2008, 04:42:36 pm »
Thank you, people on this forum have really been fantastically helpful. Crawling around under the van I did see a bolt with a locking nut on the end of the waste-gate. I will try turning that in a bit and see what gives. Systematically of course.
I did a search for various things but as yet had not found anything specific.
As an aside the engine seems to be loosening up a bit and the fuel consumption seems to be getting better even with the leaky IP.
Reply #19May 02, 2008, 01:32:40 pm
Baxter
« Reply #19 on: May 02, 2008, 01:32:40 pm »
Quote from: "witoke"
General consensus seems to be just to wind the fecker right in and regulate boost with your residual fuel screw.
With all the vans I have messed with I never seem to be able to achieve anything more noteworth than about 1 bar (15psi)
Reply #20May 02, 2008, 03:02:35 pm
witoke
  • 76
« Reply #20 on: May 02, 2008, 03:02:35 pm »
With that earthy a description I'm figuring your from  'oop north' somewhere..
But hey, maybe I'll try that after this weekends camping trip, once I figure out where the residual fuel screw is....
