Author Topic: Diesel (AAZ) into a Westy...  (Read 11708 times)
Reply #15April 19, 2008, 03:22:11 pm
dokarex
  • 61
« Reply #15 on: April 19, 2008, 03:22:11 pm »
How do you remove the old dip stick tube to replace it with the one from the westy.
I've tried turning and wiggling but don't want to break it off in the block.
 :D Thanks
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
Reply #16April 19, 2008, 04:26:47 pm
Baxter
« Reply #16 on: April 19, 2008, 04:26:47 pm »
The old dipstick is a very tight fit, it needs punching out from underneath, i.e sump off.
When you fit the T3 one, make sure that there is a small metal washer before the o-ring or it will leak, they are pence from VW.
