Author Topic: N/A to TD conversion  (Read 1990 times)
April 03, 2008, 10:35:05 am
blunt
  • 22
« on: April 03, 2008, 10:35:05 am »
What all is required to do such a feat besides the obvious manifolds, pump and a turbo,   what are the differences between the N/A and TD engines internally? pistons, crank, cams, oil squirters?  havent been to the insides of these engines so i really dont know what vw changed.
Thanks Will
Reply #1April 03, 2008, 10:50:31 am
« Reply #1 on: April 03, 2008, 10:50:31 am »
Just do a little searching. There are tons of threads about this, like this one. http://vwdiesel.net/phpBB/viewtopic.php?t=13069 I guess someone should do a good writeup one of these days and put it in the FAQ.
Reply #2April 03, 2008, 11:59:20 am
truckinwagen
  • 1895
« Reply #2 on: April 03, 2008, 11:59:20 am »
I turboed an N/A with the turbo and manifolds from a jetta TD.
I am running about 15psi and am working on a water/meth injector to keep manifold temps down.
on an N/A with a turbo on it an EGT gauge is essential, I try to keep the EGT's below 1200F
83 Opel Kadett Diesel
