Author Topic: for those with diferent valve covers  (Read 11430 times)
Reply #15April 12, 2008, 08:37:10 am
carrizog60
  • 978
« Reply #15 on: April 12, 2008, 08:37:10 am »
why cant i use the studs that are in the 1.6?
is the bolts are a thing to do?
Portugal
Reply #16April 12, 2008, 10:48:53 am
stewardc
« Reply #16 on: April 12, 2008, 10:48:53 am »
Quote from: "carrizog60"
You can, but the rubber gasket is an upgrade and requires a shouldered stud.
Reply #17April 12, 2008, 12:26:37 pm
cyrus #1
  • 360
« Reply #17 on: April 12, 2008, 12:26:37 pm »
Quote from: "stewardc"
You can, but the rubber gasket is an upgrade and requires a shoulderless stud.
Fixed.  :wink:
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #18April 12, 2008, 01:30:04 pm
Baselyne
« Reply #18 on: April 12, 2008, 01:30:04 pm »
both of those valve covers look great, I think I am in the market for a G60 cover if anyones selling
Reply #19April 12, 2008, 01:55:54 pm
GTD.
  • 183
    • http://tinyurl.com/6yk84
« Reply #19 on: April 12, 2008, 01:55:54 pm »
The new AAZ, has no available cover so I powdercoated that.
Can the G40 (PY code) be made to fit the AAZ?
Back on topic, I have fitted both a polished 2.0 8v (2E code) and a G60 (PG code to my 1.6 GTD (SB code) and haven't had to modify anything other than fit the neoprene gasket kit from VW
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #20April 12, 2008, 03:05:49 pm
stewardc
« Reply #20 on: April 12, 2008, 03:05:49 pm »
Quote from: "GTD."
I  WANT   THAT !  Does anyone have a spare that they would ship to me ??? I'm sure it would fit.
Reply #21April 13, 2008, 11:28:14 am
GTD.
  • 183
« Reply #21 on: April 13, 2008, 11:28:14 am »
Quote from: "GTD."
probably best to search on German Ebay for "G40 Ventildeckel"
link
Unfortunately they were only fitted to the Polo G40 (1.4 supercharged engine) so aren't very common.
VW part No. 030 103 475 F
[Oo=w=oO]Golf GTD
Reply #22April 13, 2008, 12:45:23 pm
Turbinepowered
  • 1206
« Reply #22 on: April 13, 2008, 12:45:23 pm »
Quote from: "libbybapa"
I only count 3 spark plugs.  Are the 3-cyl engines the same length of block?
Andrew
There are four plug wires there...
Reply #23April 13, 2008, 01:32:56 pm
GTD.
  • 183
« Reply #23 on: April 13, 2008, 01:32:56 pm »
The g40 (PY) which has the rocker cover that might fit the AAZ has the same block and head casting as a 1.3 (2G) (I have one of these in my garage)
if you need any sizes/dimensions of the rocker cover  let me now and Ill measure it up (bearing in mind mine is the standard pressed steel cover)
Above 1.3 2G petrol
Below 2.0 2E petrol
2g inside
[Oo=w=oO]Golf GTD
Reply #24April 13, 2008, 02:38:05 pm
MontanaGTD
  • 230
    • http://www.dub-style.com
« Reply #24 on: April 13, 2008, 02:38:05 pm »
G40 one doesnt fit! I have a G40 and a GTD and the covers very definatley dont fit!
MK3 Polo G40 - Sold
MK2 Golf GTD in Montana Green - FORSALE
MK2 Scirocco Scala 1.8i - FORSALE
MK4 Polo 6n 16v 5dr with A/C - othercar/wifes learner
Skoda Fabia VRS - new Daily
Reply #25April 13, 2008, 02:40:48 pm
stewardc
« Reply #25 on: April 13, 2008, 02:40:48 pm »
Quote from: "GTD."
Above 1.3 2G petrol
Below 2.0 2E petrol
2g inside
Send me the dimensions(email or pm). My AAZ cover hasn't been installed yet and I can compare.
Reply #26April 13, 2008, 03:25:50 pm
GTD.
  • 183
« Reply #26 on: April 13, 2008, 03:25:50 pm »
Quote from: "MontanaGTD"
but your GTD is an SB with the 8 studs along the edge his is an aaz (MK3) with the 3 in the middle?
[Oo=w=oO]Golf GTD
Reply #27April 13, 2008, 04:24:30 pm
stewardc
« Reply #27 on: April 13, 2008, 04:24:30 pm »
Yeah, a GTD is a 1.6. The AAZ is a 1.9.
Reply #28April 14, 2008, 12:02:28 am
carrizog60
  • 978
« Reply #28 on: April 14, 2008, 12:02:28 am »
what bolt sizes needed to the 2.0 cover?
any pics?
i dont know what you mean by shoulderness ... :oops:
Portugal
Reply #29April 14, 2008, 01:50:04 pm
MontanaGTD
  • 230
« Reply #29 on: April 14, 2008, 01:50:04 pm »
What dimensions you need? between the bolts and the exterior dimensions? I have a couple of them!
MK3 Polo G40 - Sold
