Author Topic: Oil pump interchange?  (Read 5269 times)
Reply #15April 04, 2008, 07:05:18 am
Turbinepowered
  • 1206
« Reply #15 on: April 04, 2008, 07:05:18 am »
Quote from: "janb"
actually I think the very early 1.5's had a spline drive instead of the tab.  (these are probably the ones with curly oil line.  The 36mm probably will fit but I would like to look at the mounting surface of each, and BE SURE the drive engages fully !!!
The early 1.5's had the shallow 4 qt oil pan as well.
Are you actually turboing a 1.5 block??
I've been thinking of trying that, as I like the RPM of the 1.5, and most of mine have been more economical than 1.6 or 1.9.  I really want a 75 MPG Scirocco or Rabbit, as I can't stand that a Honda insight gets better mileage.  I felt a turboed 1.5 (driven very carefully) would be the best bet. (I could be wrong...) :oops:
Yes and no. Yes, I am putting a turbocharger on a 1.5 engine. No, I'm not doing it to a bone stock unmodified engine. :D
ARP studs (11mm), a slightly thicker head gasket (next notch size up, which also puts me in the range of gaskets I can actually purchase easily), fresh bolts all over the place, and no boost enrichment device up top.
The lattermost will be remedied at some point, probably the same time I invest in getting a 1.5 pump rebuilt and Giles-tuned with economy and efficiency in mind instead of out-and-out performance.
The turbo's only a K03 anywho, I'm not foolish enough to start stuffing VNT17s or big Holset's onto this fragile little waif of a diesel. :D
