Author Topic: I have my pistons out  (Read 5955 times)
Reply #15March 22, 2008, 10:55:27 pm
burnt_servo
  • 278
Re: I have my pistons out
« Reply #15 on: March 22, 2008, 10:55:27 pm »
Quote from: "Mexe"
So on the advice of my mechanic I took my pistons out to do my rod bearings and the rings on the pistons. He said my main bearings will not be a problem and to not touch them so the crank is still in the car but is there anything else I should do while this is out? It is a 1.6L TD and I am intercooling it and upping the boost.
pull the upper #1 main bearing and check it ..... that is the one that wears first .
for the price of a set of bearings , you be silly not to change them .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #16March 23, 2008, 11:52:34 am
sprstu
  • 99
« Reply #16 on: March 23, 2008, 11:52:34 am »
I am so glad I clicked on this page as i am about to do rings and main bearings. Vince Waldon is the man, so helpful to us youngins and noobs.
Mk1 caddy TD, mk4 Golf Tdi
Reply #17March 23, 2008, 12:00:57 pm
« Reply #17 on: March 23, 2008, 12:00:57 pm »
Just remember, youngins, Grampa Vince *strongly* advises complete engine removal and disassembly for *all* rebuilds.
Cheating is evil and rotten and will cause your teeth to fall out when you get to be my age.   :wink:
Reply #18March 23, 2008, 01:10:04 pm
Baselyne
« Reply #18 on: March 23, 2008, 01:10:04 pm »
Quote from: "sprstu"
That's what im talkin about
vince rules
Reply #19March 23, 2008, 04:03:10 pm
Mexe
  • 22
« Reply #19 on: March 23, 2008, 04:03:10 pm »
Ok so I am going to check one main bearing next time I am at the car and see how it is looking and decide from there what I am going to do.
Another question, on my #2 and #4 piston instead of a nice smooth edge around the top there is a tiny place on each one where it kind of craters. Is this a problem and need to be dealt with or should it be fine?
Reply #20March 24, 2008, 04:45:33 am
« Reply #20 on: March 24, 2008, 04:45:33 am »
I am another youngin ... but I found this interesting in the faq. If you are doing main bearings this could be of use.
http://vwdiesel.net/phpBB/viewtopic.php?t=3611
Reply #21April 10, 2008, 11:54:11 am
myke_w
  • 1099
« Reply #21 on: April 10, 2008, 11:54:11 am »
Quote from: "Vincent Waldon"
I totally concur, do it once, do it right.
