Author Topic: Jake's KKK K24 Rebuild - restored  (Read 57411 times)
Reply #30April 28, 2009, 09:52:51 am
Darkness_is_spreading
  • 288
« Reply #30 on: April 28, 2009, 09:52:51 am »
Hey I need to know the exact bolt size for the exhaust side bolts that connect the casting to the cartridge. I measured them and they were spot on to 8mm, I picked up some bolts that are under grade 8 strength.
I think I need to re-tap the holes, and try again but if anyone can confirm that they are 8 mm that would be great.
I will post picks of the Hybrid Turbo build.
92 Jetta 1.6 T (Sleepin)
Reply #31April 28, 2009, 11:34:21 am
starrd
  • 128
Re: ....
« Reply #31 on: April 28, 2009, 11:34:21 am »
Quote from: "Darkness_is_spreading"
I will measure a spare one tonight if you like and I will post the info back here.
OK - for K24 the 6 bolts are 8mm x 1.25 pitch x 16mm long
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #32April 30, 2009, 08:03:58 pm
  • 288
« Reply #32 on: April 30, 2009, 08:03:58 pm »
Thank you sir, I needed that info as I cannot locate the original bolts.   Had to re tap all the holes tonight, will take some pics, and build it tomorrow.
Reply #33February 24, 2012, 09:19:18 am
Re: Jake's KKK K24 Rebuild - restored
« Reply #33 on: February 24, 2012, 09:19:18 am »
great write up.. should be put in a FAQ or something..
Reply #34February 24, 2012, 10:07:17 am
CrazyAndy
  • 739
« Reply #34 on: February 24, 2012, 10:07:17 am »
x2!  Actually just mentioned and relinked to this in my build direction query thread.
Reply #35February 24, 2012, 06:25:49 pm
« Reply #35 on: February 24, 2012, 06:25:49 pm »
Jackpot. That is the link I was telling you about in the other thread, I used it for reference whenever I put my wastegate back on my turbo.
Reply #36July 11, 2017, 03:17:37 pm
oblique
  • 317
    Diesel while you can.
« Reply #36 on: July 11, 2017, 03:17:37 pm »
Pics are down...any way to resurrect?
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
