Author Topic: we need an electrical wiz for a VNT  (Read 7197 times)
March 14, 2008, 03:55:58 pm
  • 1739
« on: March 14, 2008, 03:55:58 pm »
Wouldn't it be possible to build a small processor to control a VNT on a mTDI?  All it needs is inputs for rpm, boost pressure, possibly elevation and 1 or 2 other variables. Then the output for a n75. Does it exist already
and i don't know?
Reply #1March 14, 2008, 04:30:29 pm
RabbitGTDguy
  • 1274
« Reply #1 on: March 14, 2008, 04:30:29 pm »
There have been several threads on this topic and no definitive solutions and or answers. I remember a pricey solution just a few months ago...however, the power vs. cost of it just wouldn't float my boat in the least. I'd greatly consider a VNT if I could find or create such a controller and a turbo that will support what i'd like it too. I'm not a fan of the mechanical linkages complexity but haven't dove into it myself...
Would be a great DIY or product if someone could do it...I know of several that were looking at it...but I never saw anything come from it.
Joe
1972 VW Westfalia
2001 Audi TT 225 Quattro Roadster (something newer :) )
Reply #2March 14, 2008, 05:41:00 pm
KTZed
  • 170
« Reply #2 on: March 14, 2008, 05:41:00 pm »
You could buy a megasquirt and probably use the boost control function built in or devise your own using the GPIO section of the board. This is just speculation on my part as I have not personally done this or even played with megasquirt at all but I do know that ppl use it to control boost electronically with a solenoid inline with the wastegate so theres no reason it couldnt be done with the VNT pot IMO. Cost about $150
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
Reply #3March 15, 2008, 08:25:04 am
lbreton
  • 56
Re: we need an electrical wiz for a VNT
« Reply #3 on: March 15, 2008, 08:25:04 am »
Quote from: "the caveman"
and i don't know?
There is a controller design that works in the thread below.  Not the first product listed in the thread. Read further down. It was created by user Ventil.  It will cost you about 100.00 to build.  It will do everything you need.
http://www.vwdiesel.net/phpBB/viewtopic.php?t=11793
'97 F250 5.9 Cummins, POD's, PDR cam, Custom Pump, Stage II Port, 14CM, blabla
'92 Passat Syncro- AHU eTDI, PP520's, 2.5 Str
'99 Audi A4 Quattro - 2.0 BHW TDI, EDC15P, GT2056V, AWIC, 5Speed Euro Tranny - 214Whp/363TQ
Reply #4March 15, 2008, 05:57:40 pm
RabbitGTDguy
  • 1274
« Reply #4 on: March 15, 2008, 05:57:40 pm »
Apparently I did read far enough! That does look fairly simple. Now, to find it stateside here!
Joe
1972 VW Westfalia
Reply #5March 16, 2008, 08:47:47 pm
lbreton
  • 56
« Reply #5 on: March 16, 2008, 08:47:47 pm »
Quote from: "RabbitGTDguy"
Joe
I am going to build two of them next month. One for a friend (VNT15 on a 1.6TD) and one for my Cummins 5.9.  I will be adding a TPS, so that will take a bit of experimenting.
Reply #6March 17, 2008, 03:16:48 am
RabbitGTDguy
  • 1274
« Reply #6 on: March 17, 2008, 03:16:48 am »
very nice...i'm trying to check on the parts availblity on this side of things...
Joe
1972 VW Westfalia
Reply #7March 17, 2008, 08:17:48 am
KTZed
  • 170
« Reply #7 on: March 17, 2008, 08:17:48 am »
Quote from: "lbreton"
Joe
Keep in mind that the megasquirt boost control is made to work with a TPS and is tunable via a 6x6 table in the software. See these links...
http://www.e30tech.com/forum/showthread.php?s=7fe1ebeb867cf743c6684a264d796b20&t=30543
http://forums.turbobricks.com/showthread.php?t=80599
PS. This will allow you to set any boost level at any rpm and throttle angle which woudl allow you to run a big turbo without surging the compressor
Reply #8March 17, 2008, 12:30:20 pm
lbreton
  • 56
« Reply #8 on: March 17, 2008, 12:30:20 pm »
Quote from: "KTZed"
I only had time to do a quick skim through the article. That looks like an interesting option too. I know the mega squirt has a good solid reputation.  What does it cost for the v3.0 board now days?
Reply #9March 24, 2008, 03:57:43 am
Bo Gunnar
  • 4
VNT control by an airvalve
« Reply #9 on: March 24, 2008, 03:57:43 am »
I have followed this discussion for some time now and have not seen a solution with an air valve that "inverts" the vacuum signal.
Function:
In normal position vacuum is connected to the VNT. This valve is controled by boost pressure via a boost control valve. When boost pressure reaches a set level the valve flipps over and vacuum signal is blocked and VNT is vented.
This kind of valve is shown on:
http://www.boschrexroth.com/pneumatics-catalog/content/AllPlatForms/Vornavigation/xMedia/en/pdf/PDF_p31034_en.pdf
Bo Gunnar
BGA
Reply #10March 24, 2008, 04:51:27 am
« Reply #10 on: March 24, 2008, 04:51:27 am »
I have a valve that has both a NO and NC port that I got at a pneumatic place for somewhere around $25. I think this is mine, or it is similar. I really don't see why you'd need a 5 way valve to control a VNT. A 3 should work.
Reply #11March 25, 2008, 12:15:18 am
  • 2930
« Reply #11 on: March 25, 2008, 12:15:18 am »
We'll have to figure a way to use a cruise control.
 Hold the boost at a certain pressure, instead of a different speed.
Reply #12March 30, 2008, 02:41:25 am
Bo Gunnar
  • 4
« Reply #12 on: March 30, 2008, 02:41:25 am »
Yes jimfoo, a 3-port valve should work. I just grabbed a picture I had. These valves are realy cheap, but does it work? Has anyone tested it?
BGA
Reply #13March 30, 2008, 06:41:13 am
« Reply #13 on: March 30, 2008, 06:41:13 am »
The valve I have seems to work fine, not that it is on anything at the moment.
