Author Topic: Turbo exhaust  (Read 16272 times)
Reply #15March 05, 2008, 02:57:36 am
regcheeseman
  • 714
Turbo exhaust
« Reply #15 on: March 05, 2008, 02:57:36 am »
Made a few and selling them on ebay uk.
Reply #16March 05, 2008, 10:04:36 am
Baselyne
Turbo exhaust
« Reply #16 on: March 05, 2008, 10:04:36 am »
link?
Reply #17March 06, 2008, 01:37:51 am
Torchd
  • 372
Turbo exhaust
« Reply #17 on: March 06, 2008, 01:37:51 am »
Hmm...  i plan to run a straight pipe as well///  where do i start that from?? right after the turbo or after the "C" clamps??  and i wana do a 3inches setup...   will that be a problem on 1.6TD mkII??  like not enough space or not enough back pressure???
Reply #18March 06, 2008, 09:54:01 am
TedV
  • 182
Turbo exhaust
« Reply #18 on: March 06, 2008, 09:54:01 am »
on diesel the straight pipe starts at the turbo outlet.  Problems in fitting a 3" pipe is the size.  Quote from the shop that did my 2.5" on the Mk3 TDi " 14 years doin exhaust and I aint never put no 2.5" pipe on a VW..."   :lol:
back pressure is the DEVIL!!  :wink:
Reply #19March 06, 2008, 11:40:29 pm
Torchd
  • 372
Turbo exhaust
« Reply #19 on: March 06, 2008, 11:40:29 pm »
So u mean i can do a 3" straight pipe??   and what do u mena by "back pressure is a devil"????
U mean its good??
Reply #20March 07, 2008, 09:43:26 am
TedV
  • 182
Turbo exhaust
« Reply #20 on: March 07, 2008, 09:43:26 am »
some folks on here have run 3" from the turbo all the back, so yes you can do that if you can make it fit.
I watched the movie "Waterboy" the ther day,  "It's the DEVIL!!" was stuck in my brain.  Big pipe= lower back pressure, turbo's usually don't like back pressure after the turbo.
Reply #21March 09, 2008, 06:52:28 pm
gilligan5000
  • 63
Turbo exhaust
« Reply #21 on: March 09, 2008, 06:52:28 pm »
make one man. . . $60 in bends, $18 4-bolt flange, $20 flex pipe, 6-18 beers and like 3 hours.  Plus you get to say you made it!  I did 3" turbo back, side exit before the rear.
Good luck, and have fun
Reply #22March 10, 2008, 01:16:08 am
Torchd
  • 372
Turbo exhaust
« Reply #22 on: March 10, 2008, 01:16:08 am »
Thanx man!!!
I live in pakistan...  so i cant get the flange here... i reckon i'll have to get one made...
so a 3" pipe is an easy fix.. aye??  like there is sufficient room in an mkII TD?
Reply #23March 10, 2008, 07:43:44 am
boxer246
  • 109
downpipe
« Reply #23 on: March 10, 2008, 07:43:44 am »
Sweet!
I am getting some mandrel bent tubing in today from UPS hopefully, and I already have the flange, so i'm gonna get the mig welder out and go to town.  Hopefully I can make something decent.  I gotta get a flex coupler though.  Right now I just want to get the downpipe on so I can drive the car.  Right now I just have hot exhaust coming out the turbo!
Ash
'81 VW Caddy 1.6 now a TD
'88 Vanagon (building a AHU M-TDI)
Reply #24March 12, 2008, 08:24:03 pm
speedy
  • 120
Turbo exhaust
« Reply #24 on: March 12, 2008, 08:24:03 pm »
Quote from: "Op-Ivy"
I take it that flex fit thing eliminated the doughnut type thing? This might be something to think about considering I can't get mine to seal....
What is this doughnut type thing of which you speak?  I don't have anything like that.
-David
Reply #25March 18, 2008, 03:38:46 am
Torchd
  • 372
Turbo exhaust
« Reply #25 on: March 18, 2008, 03:38:46 am »
I was at the exhaust faricator yesterday.. the turbo back flange cannot take the 3 inch pipe as the hole on the flange is about 2.25 inches... if i do get it welded.. i wont be able to tighten the 4 bolt on studs...
i really wana go for the 3 inch setup.. so i was thinking of either geting it tappered from the turboback end or going for the 2.5inch setup.
Guyss.... how can i go for the 3 inch setup.
Reply #26March 18, 2008, 06:50:35 am
Turbo exhaust
« Reply #26 on: March 18, 2008, 06:50:35 am »
Taper it to 3" as soon as you have room.
Reply #27March 18, 2008, 10:25:14 am
homerj1
  • 433
Turbo exhaust
« Reply #27 on: March 18, 2008, 10:25:14 am »
Where can a person source the flange that bolts to the turbo?
I plan to make my own downpipe for my 1.6td, as the cast down pipe has a few holes. I thought about making\cutting my own flange, but it feels like too much work.
HJ1
Reply #28March 18, 2008, 06:37:35 pm
James8485
  • 223
Turbo exhaust
« Reply #28 on: March 18, 2008, 06:37:35 pm »
i ran 2.5'' from cat back and my muffler actually fell off and i didnt put anouther one back on because it wasnt any diff in sound not loud at all.. i just put on a brullen muffler on as it almost time for an e-test here so i need to pass but i put the muffler on and no change!!! same
i had 2'' (stock) i did install 2.5'' as i heard was better for flow, motor was just overhauled so dont wanna push it to much yet but soon i will see if the exhaust did anything......hoping it will as it cost me a bit of coin!
---------James--------
Reply #29March 18, 2008, 07:43:22 pm
TedV
  • 182
Turbo exhaust
« Reply #29 on: March 18, 2008, 07:43:22 pm »
Quote from: "homerj1"
HJ1
from ATPturbo.com part number ATP-FLS-032 worked for me.  2.5" pipe at turbo outlet, opening up to 3" as soon as I could.
