Author Topic: Non-ac brackets  (Read 14442 times)
Reply #15April 09, 2005, 03:09:41 pm
chrissev
  • 694
Non-ac brackets
« Reply #15 on: April 09, 2005, 03:09:41 pm »
Quote from: "veeman"
Wow... thanks guys!   That definitely helps.
I'm having trouble identifying the "small top bracket" that others have remarked about?  It's the one that the timing belt cover attaches to.  Is this it?
Here's another view from chrissev's pics...
These things are pretty rare around here.  I'm not sure I've even seen any diesels in a yard during the last few years.
The bracket you have circled in my pic is the small top one people are talking about.  You need that to stabilize the bracket as it is quite long and held onto the block with only four bolts (that go through the water pump).  I would imagine you could manufacture one if you needed to.  The bolt/nut assembly you circled in the first picture is not the alternator bracket at all and is actually part of the injection pump backing plate.  The interesting thing about the A1 alternator brackets (shown in the first pic you posted) was that they tended to break in half.  You could fix them by welding them back together.  The A2's don't seem to do this.  But the interesting thing about the A2 brackets is they are much harder to remove as there is almost no access to the top two bolts.
Reply #16April 09, 2005, 08:30:38 pm
  • 2931
alternator bracket
« Reply #16 on: April 09, 2005, 08:30:38 pm »
 Not so...
 The upper timing belt cover on an A1 is bolted to the small bracket, on top of the alternator bracket.
 Here's one I bought awhile back on ebay:
 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=7951326896&sspagename=STRK%3AMEAFB%3AIT
 Same kind as is in the top picture.
 ...which ... has no lower timing belt cover?
Reply #17April 11, 2005, 08:28:16 pm
srivett
  • 318
Non-ac brackets
« Reply #17 on: April 11, 2005, 08:28:16 pm »
I think all you need is the long alternator pulley.  Once you have the AC pump removed push the alternator down and have a new adjustment bar made to come up from below the alternator.  You'll need some strap steel with a hole and a long slot made up.  My car has this setup but the adjustment strap is up on top and I have a really long 1170 belt.  The belt rubbed on the timing cover so I removed the cover and filed off a ridge.
Steve
1992 1.6D Golf - 412K km
Reply #18April 14, 2005, 09:05:29 am
rackley
  • 96
Non-ac brackets
« Reply #18 on: April 14, 2005, 09:05:29 am »
Is the reason everyone wants to do this mod because they have belt problems with the AC to Alternator system?
Ray
www.vocontrol.com
VO Control - Programmable VegOil and WVO Controllers
Reply #19April 14, 2005, 10:21:39 am
veeman
  • 421
Non-ac brackets
« Reply #19 on: April 14, 2005, 10:21:39 am »
For me, no...  I want to get rid of the extra weight and complexity associated with those systems.  I've done the conversion on a few gas motors and it really makes that whole area better to work in AND drops a few pounds (important on cars that don't have huge hp to begin with.
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #20April 14, 2005, 04:06:17 pm
srivett
  • 318
Non-ac brackets
« Reply #20 on: April 14, 2005, 04:06:17 pm »
The AC belts on my car only lasted 20,000 km at a time so eventually the previous owner had a fit and got all the AC junk ripped out.  It is a horrible design to begin with and even if you switch to the 1.9l serpentine system you still have to use a V belt for the power steering.   :twisted:
Steve
Reply #21April 14, 2005, 04:14:53 pm
chrissev
  • 694
Re: alternator bracket
« Reply #21 on: April 14, 2005, 04:14:53 pm »
Quote from: "fatmobile"
 Not so...
I don't think it is like that on all the A1s.  That bracket to the alternator bracket might have been a later addition.  It looks like it is bolted on both sides of the bracket (one to the timing belt cover, other to the alternator bracket).  On both my 79 diesel rabbits the alternator bracket could be removed by simply removing the four bolts that held it to the engine.  So I think that the bracket to the timing belt cover was a later addition, perhaps only on the US built cars.
Reply #22April 14, 2005, 05:35:15 pm
fspGTD
  • 1529
Non-ac brackets
« Reply #22 on: April 14, 2005, 05:35:15 pm »
The piece connecting alternator bracket to injection pump bracket also supports the front of the A1 diesel's timing belt cover.  So if this piece was missing in your '79, then how was the front of the timing belt cover supported?
Jake Russell
Reply #23April 14, 2005, 06:28:30 pm
Mark(The Miser)UK
  • 1557
Non-ac brackets
« Reply #23 on: April 14, 2005, 06:28:30 pm »
On the TD Quantums (Non a/c) the alternator is positioned on the same side as the starter maifolds. (With or without power steering)Which is next to water pump.
Mark-The-Miser-UK
Reply #24April 15, 2005, 12:58:07 am
  • 2931
alternator bracket
« Reply #24 on: April 15, 2005, 12:58:07 am »
He's right, the '79 would have the welded steel alternator bracket. Not the cast iron one in the picture.
 There is one on ebay now and you can see the part that comes up high and bolts to the upper timing belt cover. There isn't a small bracket attached to the top. I had one of these and it cracked so I went with the later, cast iron bracket.
 I had to change injection pump brackets too because of where the alternator bracket bolts to the injection pump bracket. I had to match the brackets or they wouldn't mate up.
 Your '79 have the lower injection pump bolt from the pump side? Instead of the nut from the gear side?
Reply #25April 15, 2005, 05:50:22 pm
chrissev
  • 694
Non-ac brackets
« Reply #25 on: April 15, 2005, 05:50:22 pm »
Quote from: "fspGTD"
it was supported on the backing plate.  And also by a carriage type bolt (T-head) that went through the water pump.  Neither of my 79s had the bracket in the first picture.  The alternator bracket broke in half on the first 79 I had, and I had to take it out to get it welded.  Four bolts and it was out.  No bracket.  Might just have been on the US built 79s that that bracket was present.  Both mine were German built Canadian imports (round headlights).  I never have owned a square headlight Westmoreland car so I don't know what the bracket situation was like on them, but I have a feeling that it was different, as illustrated by the extra bracket in the first picture that attaches to the timing belt cover, that neither of my german 79s had.
Reply #26April 15, 2005, 05:56:01 pm
chrissev
  • 694
« Reply #26 on: April 15, 2005, 05:56:01 pm »
as far as I can recall, two bolts were on the pump side, and one on the gear side.
