TDI Engine -General Info
Source for BEW/ BRM rebuild parts
Topic: Source for BEW/ BRM rebuild parts (Read 8579 times)
February 11, 2008, 01:45:12 pm
Greasecar
February 11, 2008, 01:45:12 pm »
I' trying to put my PD engine back together and I'm looking for BRM rings and BEW bearings. So far I can only find them through the dealer and even whith my discount rings are $117/cylinder and bearing shells are sold individually at $17/ piece!!!! Too bad the machine shop chucked the rings when they cleaned and measured the pistons, they only had 10K on them.
Anyone know of an aftermarket source?
www.greasecar.com
79 Mini diesel (1.5 Peugeot)
82 rabbit TD (given to Junkcollector Jay)
84 rabbit TD (intercooled w/ VNT)
82 rabbit PD (undergoing swap)
01 Golf TDI (burned to the ground)
02 Golf TDI (355,000 miles and counting)
04 Passat TDI Wagon (Grocery getter)
February 11, 2008, 09:21:26 pm
shortysclimbin
February 11, 2008, 09:21:26 pm »
total seals should be able to get you a nice set of rings. Bearings if I am not mistaken are the same as the 2.0 and 1.8l gas motors. So you should be able to get rings from any dealer that sells them. Although I am not 100% sure on everything on that. ETKA is a good way to check...
February 13, 2008, 11:30:55 am
myke_w
February 13, 2008, 11:30:55 am »
I can sell you a complete Glyco main bearing set for 45, thrust bearings for 15 and a full set of std *BEW Goetze rings for 80..
PM me if you still need parts..
February 20, 2008, 07:15:54 am
Greasecar
February 20, 2008, 07:15:54 am »
Myke-
I PM'd and emailed you on those parts but haven't heard back. Is there another way to get a hold of you? Anyone have ideas?
-Justin
www.greasecar.com
February 20, 2008, 07:22:11 am
myke_w
February 20, 2008, 07:22:11 am »
Sorry for the delay, I'm super duper busy these days..
I'm coming up dry on the BRM parts man...
I can do the main bearings and thrust washers though...
Let me know if that will help you out..
February 20, 2008, 01:10:13 pm
Greasecar
February 20, 2008, 01:10:13 pm »
Can you get the BEW rod bearings as well as the mains and thrust washers?
Anyone know if the BRM and BEW rings cross over? I can't belive the machine shop chucked them on me, now I can't even take measurements off of them!
www.greasecar.com
February 20, 2008, 01:29:44 pm
myke_w
February 20, 2008, 01:29:44 pm »
If it helps any the part # is 03G198151C for a set... I'd say dealer is your best bet at this point, there's nothing in the aftermarket for anything that new..
February 21, 2008, 06:51:32 am
Greasecar
February 21, 2008, 06:51:32 am »
I had sourced the rings through the dealer and they are available bit at a cost of $120+ per cylinder.
Here are the BEW and BRM pistons next to each other. I measured the grooves and they are identical as well as the cylinder bore and piston diameter. The only obvious difference is the hight of the piston and related position of the top ring groove. Can anyone see any reason that the BEW rings will not cross over?
www.greasecar.com
February 21, 2008, 07:07:18 am
myke_w
February 21, 2008, 07:07:18 am »
I'd say if they fit and are the same shape, you shouldn't have a problem, as long as the BRM rings don't have any weird characteristics.
FYI the BRM part # does not cross to any other vehicle..
I'd give it a shot.. it's a lot of savings money saved if it works.
February 21, 2008, 07:26:04 am
Greasecar
February 21, 2008, 07:26:04 am »
Do the BEW or ALH PN's cross with eachother or anything else? I remember that the BEW and BRM numbers only have one or two digits difference but I have no idea of what the significance is.
www.greasecar.com
February 25, 2008, 06:55:23 am
Greasecar
February 25, 2008, 06:55:23 am »
Myke-
I had my machine shop double check my findings and was told that all of the piston groove and bore dimensions are identical between the BEW and BRM. The shop deals with Hastings rings and were told by Hastings that they show the same part number all the TDI applications.
In any case I want to get the BEW rings and bearings from you. I'll send you an email as well but wanted to put the word out that I am looking for a total on all the parts to order them up.
www.greasecar.com
