Author Topic: Quantum Syncro + 2.0 L Audi TD, project for sale...  (Read 39673 times)
March 30, 2005, 08:56:03 pm
jackbombay
  • 599
« on: March 30, 2005, 08:56:03 pm »
Here is a pic of my engine bay which was vacated today by the gasser that used to live there, Anyone want to buy a 5 cylinder Gasser?
  Here is a pic of the 2.0 L 5 banger Audi TD that will take its place  :D
  Maybe 2 weeks to have it in the car, I need a new clutch and the flywheel needs resurfacing, plus there are a few other fissues to work out, battey needs to go somewhere else, fuel tank filler neck needs to be replaced with Diesel sized one, fuel line/fuel pump removal...
Reply #1March 30, 2005, 09:47:39 pm
Dr. Diesel
  • 1341
« Reply #1 on: March 30, 2005, 09:47:39 pm »
sweet... AWD TD... i love it.
Reply #2March 31, 2005, 01:23:14 am
Mark(The Miser)UK
  • 1557
« Reply #2 on: March 31, 2005, 01:23:14 am »
Quote from: "Dr. Diesel"
To give it its full name: :shock:  QAWD TD :shock:
 :mrgreen: Sounds like a  dyslexic HiFi Television; but a Bang & Olufsen to those that know :mrgreen:
Mark-The-Miser-UK
Reply #3March 31, 2005, 05:39:59 am
moTthediesel
  • 194
« Reply #3 on: March 31, 2005, 05:39:59 am »
Jack,
I've pulled the prime mover from my Quantum TD and stripped it to a husk. If you are short any little bits and pieces, let me know.
By the way, -- v. cool project  8)
moT
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
Reply #4March 31, 2005, 06:41:06 am
VWRacer
  • 649
« Reply #4 on: March 31, 2005, 06:41:06 am »
That is SO right!  :D
Stan
C-Sports Racer
Reply #5March 31, 2005, 08:32:12 am
jackbombay
  • 599
« Reply #5 on: March 31, 2005, 08:32:12 am »
Quote from: "moTthediesel"
Jack,
moT
   I've got most of the Quantum bits I need, but there are a couple bits I need for the Audi motor that are difficult to locate.
  There is a female threaded fitting on the vaccum pump that is about 3/4 of an inch, the other end needs to be barbed for the large vac line that runs to the brake booster :?
   I also need a similar fitting, but smaller for where boost is supplied to the top of the IP, 8 by 1 metric fitting that needs hose barbs on the other end, I have a brake bleeder fitting that fits, but is not ideal because there is no t a lot of space for a clamp on the other side of the barb.
Reply #6March 31, 2005, 12:50:58 pm
Zeitgeist
  • 90
    Rule Cascadia
« Reply #6 on: March 31, 2005, 12:50:58 pm »
Interesting project.  How do the Audi fives compare to the sixes found in '80's era Volvos?  Those don't appear to hold up as well as the VAG fours.  I'd like to stuff a nice five cyl. TD in my Vanagon someday.
'87 300TD (OM606)
'90 300D (OM602)
'89 Vanagon Bluestar (ALH)
'01 EV Weekender (AXK)
'04 Passat Variant (BHW)
Reply #7March 31, 2005, 04:41:09 pm
jackbombay
  • 599
« Reply #7 on: March 31, 2005, 04:41:09 pm »
I don't really know on the first question, and I don't think that the 2.0 will fit in a vanagon, but it might just not fit in a syncro vanagon. Caddywompus tried and it did not work, I think it was a syncro he tried to bolt it up to.
Reply #8March 31, 2005, 05:57:50 pm
Mark(The Miser)UK
  • 1557
« Reply #8 on: March 31, 2005, 05:57:50 pm »
Here is some rpm to mph math that I have worked out from first principles:
All resultsare @3000rpm.
All results are based on effective wheel height of 23" except where stated.(Syncro has 14" wheels?)
 :mrgreen: 5 speed Rabbits are  about 74mph IIRC :mrgreen:
Fd =final drive.        5th is 5th gear
Quantum 1.6TD
'Fd x5th' is 4.11 x 0.73      =68mph
Quantum 5cyl Gasser
................4.9 x 0.53        =79mph
Quantum Syncro
................4.11 x 0.83      =60mph :cry:
 but with 25"   wheels        =65mph
using 5 cyl 5th 4.11 x 0.53 = 93mph
and with 25" wheels:         =102mph :shock: [ or 2060rpm @70mph :lol: ]
Mark-The-Miser-UK
Reply #9March 31, 2005, 07:39:03 pm
jackbombay
  • 599
« Reply #9 on: March 31, 2005, 07:39:03 pm »
Quote from: "Mark(The Miser)UK"
Quantum 5cyl Gasser
Quantum Syncro
   Does anyone know if the internals can be swapped between the two trannies? Swaping all the gears seems to make the most sense so there would not be a huge canyon between 4th and 5th.
Reply #10April 01, 2005, 12:36:37 pm
veeman
  • 421
« Reply #10 on: April 01, 2005, 12:36:37 pm »
Well, if they're anything like the gas 5-cyl's, they're probably bulletproof.  The 5-cyl NA and turbo engines in the gas cars were WAY overbuilt and took a lot of abuse.
I took apart an MC turbo engine with more than 150k on it and the bearings / cylinders looked barely used...
Sounds like a great project.
BTW, I'm not sure if the trans / diff in the QS is the same as the US Audi 4kq / 5kq units, but I do know that people have switched out the 4.11 in the 4kq  for slightly longer gears in the 5kq's while doing turbo (gas) swaps.  I believe those are 3.89.  They seem to like it.
I can find more info if you like...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #11April 01, 2005, 06:42:12 pm
therabbittree
  • 299
« Reply #11 on: April 01, 2005, 06:42:12 pm »
I am collecting parts  for the same swap.... I am interested in finding out more about  this 5th gear swap or fianl drive swap ..or both 389 finals and  .53 5th gear would be nice....a 2.5 tdi would be best but out of my budget..i hope i can get some decent power from th e2.0 5TD..and i hope i can get it to start unpluged when its real cold  with out issues..my old idid aways started suckin g in th ecold unaided..the tdi starts much better in cold even ral cold 10-20below..unplugged.. think i could egt a idi to start in those conditions with out being plaugged in?
... we need more pics and test results..my syncro needs brake work and waspping ..too many projects yet ha
keep ip the good work
later
Deo
\x/ hillfolk!
Reply #12April 05, 2005, 06:24:43 am
veeman
  • 421
« Reply #12 on: April 05, 2005, 06:24:43 am »
Maybe this will help for the transmission questions...  It's from an Audi board, but the transmission in the quantum should be the same unit as those from the 5kq / 4kq...
http://www.motorgeek.com/phpBB2/viewtopic.php?t=1533
81 Caddy TD
83 VW GTI FSP
86 4ktq
Reply #13April 05, 2005, 07:44:04 am
Mark(The Miser)UK
  • 1557
« Reply #13 on: April 05, 2005, 07:44:04 am »
Quote from: "veeman"
I thought the type 016 box was for the quantum sync But would the gears from the type 093  drop into the type 013 boxes which are the 1.6TD/4 cylinder gasser boxes or is it confined to the type 093 boxes...
Huh? :roll:
Mark-The-Miser-UK
Reply #14April 10, 2005, 08:00:19 pm
jackbombay
  • 599
Engine in car.
« Reply #14 on: April 10, 2005, 08:00:19 pm »
YESSSSS!!!!!
  Engine in car. Drivers side motor mount was different between the Audi and the quantum, it swapped right over from the old gasser motor to the Diesel though and is looking good now. Nothing unusuall or hard to deal with so far.
   Still need to figure out, fuel filter mounting, battery relocation, removing an air box mount for turbo clearance, fuel pump removall, empty gas tank, etc... Maybe have it running next weekend???
