Author Topic: Bad bearings or bend rod? Quick quiz  (Read 11088 times)
Reply #30October 31, 2008, 03:45:43 pm
Hammy
  • 169
« Reply #30 on: October 31, 2008, 03:45:43 pm »
I replaced a motor with an old one I had kicking around. When I started it up it ran perfect. Then I went around the block, and it started knocking exceptionally loudly, as if I had spun a bearing. Oil pressure was perfect, and the needle wasn't bouncing around as if a bearing was done. I changed the injectors over to the ones from the motor that came out, and noise was gone. Bad injector!!!
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
