Author Topic: Glowplug timing control/newbie, help  (Read 2042 times)
January 11, 2008, 03:48:01 am
haybayian
  • 155
« on: January 11, 2008, 03:48:01 am »
Is there an alternative to a VW glowplug control unit from the dealer? I can't believe that buying a new one would cost nearly $400 CAN.
Thanks for your advice.
Haybayian
Keep it simple if you can.
Reply #1January 11, 2008, 04:48:28 am
somolovitch3
  • 290
« Reply #1 on: January 11, 2008, 04:48:28 am »
Find one at a salvage yard, post in WTB, check with NAPA or such.
When you get one, PUT A RELAY on its output!!!!!!!
Usually that is the portion that fries. One or two 40 Amp relays to feed the glow plugs from the batt (via a fuse and larger wire) will keep this from happening again (one hopes).
Or a large switch (amp wise) and bypass  everything.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #2January 11, 2008, 06:04:51 am
haybayian
  • 155
« Reply #2 on: January 11, 2008, 06:04:51 am »
Quote from: "somolovitch3"
Thanks for the tip.
Haybayian
Reply #3January 11, 2008, 07:13:24 am
flash319
  • 163
« Reply #3 on: January 11, 2008, 07:13:24 am »
Get an old external starter solinoid from crappy tire and and put a switch on your dash that activates the coil for the solinoid.  Have the switch spring return then you heat as long as you are holding the button.
Reply #4January 11, 2008, 08:13:22 am
slorimer
  • 52
« Reply #4 on: January 11, 2008, 08:13:22 am »
Would someone be able to describe the location of the glow plug control unit on an A3 Jetta?
94 1.9TD
