Author Topic: Where To Get Injectors Tested/Adjusted in GTA?  (Read 7477 times)
January 04, 2008, 06:48:36 am
duffer
  • 164
« on: January 04, 2008, 06:48:36 am »
Does anyone have the name of a good, reliable
  shop, in the GTA, to test/adjust my TD injectors?
  And what's the usual charge per injector?
  I have lapped the sealing surfaces with
  400, 600, 800 and, finally, 1500 grit sandpaper,
  on a piece of plate glass.
  However, in a conscientious effort to obtain a
  perfectly smooth, flat surface, I may have been
  a trifle over-zealous :roll: .
  I read, somewhere, that the lapping process can
  significantly increase the breaking pressure. So,
  testing/adjusting is highly recommended.
  Is there a diesel shop, in the Greater Toronto Area,
  frequented by members of this forum, equipped to
  accurately set the breaking pressure?  And how much
  do they usually charge? (I have eight injectors to do).
  Any names, information would be greatly appreciated.
  Thank you.
Reply #1January 04, 2008, 09:32:40 am
« Reply #1 on: January 04, 2008, 09:32:40 am »
Look in the Vendors section for Giles
Reply #2January 04, 2008, 10:31:55 am
« Reply #2 on: January 04, 2008, 10:31:55 am »
Talking to Giles, he says they should be lapped with some far finer than 1500 grit.
Reply #3January 04, 2008, 01:44:40 pm
duffer
  • 164
« Reply #3 on: January 04, 2008, 01:44:40 pm »
Quote from: "jimfoo"
  Really? :shock:
  Just how far, beyond 1500 grit, does
  he recommend?
  Most of the posts I've read, on lapping
  injectors, didn't seem to take the
  process much beyond 600 grit.
  I thought I was being over cautious.
  I guess I'd better start looking for
  2000/2500 grit wet/dry sanpaper.
  Thanks for the information.
Reply #4January 04, 2008, 05:10:46 pm
« Reply #4 on: January 04, 2008, 05:10:46 pm »
I'm hoping others chime in here... I've always gone up to 600 in the past and never had a problem. but a set I just built for someone else evidently is leaking... might be a fluke, or my torque wrench is wonky... or perhaps 600 *is* too coarse and I've just been lucky so far....
Anyone else care to share their injector lapping standards ???
Reply #5January 04, 2008, 05:44:25 pm
blkboostedtruck
  • 1535
« Reply #5 on: January 04, 2008, 05:44:25 pm »
I been going up to 1000 grit! so far no problems!
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #6January 04, 2008, 08:36:28 pm
duffer
  • 164
« Reply #6 on: January 04, 2008, 08:36:28 pm »
Quote from: "Vincent Waldon"
  I read your very well-written and informative post
  on the subject of lapping injectors, for which I thank
  you, and none of those, who followed your procedure
  seem to have encountered any problems with 600 grit.
  I'm hoping that Giles's standards are counsel for
  perfection and that somewhat lower standards can
  prove to be quite adequate and satisfactory.
  Perhaps others will share their expertise/experiences.
  In the interim....thanks again.
Reply #7January 04, 2008, 09:39:38 pm
« Reply #7 on: January 04, 2008, 09:39:38 pm »
Quote from: "duffer"
Thanks for your kind words !!
I believe the gold standard here, according to Dr. Bosch,  is a microtome... a precision shaver that is able to take very fine cuts at very straight angles and leave the surface mirror-smooth.
Not having one in the average shop we improvise... but perhaps we sometimes go too far sometimes.  I know we're doing stuff to the IP that makes Bosch-trained guys shudder !!
As long as it works, I guess, and up to my last set 600 grit seemed to work   :roll:
Reply #8January 18, 2008, 07:42:46 pm
Dr. Diesel
  • 1341
« Reply #8 on: January 18, 2008, 07:42:46 pm »
I've used Giles' lapping tablet. Now I believe any sort of paper that has a 'grit' rating, no matter how high, is simply way to coarse to do a proper job.
Reply #9January 18, 2008, 08:22:02 pm
« Reply #9 on: January 18, 2008, 08:22:02 pm »
Cool... able to share any further details ??  Grit / type of lapping compound ?!!
Reply #10January 18, 2008, 10:05:37 pm
Dr. Diesel
  • 1341
« Reply #10 on: January 18, 2008, 10:05:37 pm »
it was green.  :P  Rubbing it between my fingers, i was unable to detect any grittiness whatsoever. Very fine.
Reply #11January 18, 2008, 10:13:15 pm
Baselyne
« Reply #11 on: January 18, 2008, 10:13:15 pm »
so you tested them with Gilles then? How much did you end up paying for each injector?
Reply #12January 19, 2008, 02:51:57 am
« Reply #12 on: January 19, 2008, 02:51:57 am »
Giles and Dr Diesel are good friends so I don't think that would apply :P
Reply #13January 19, 2008, 06:46:14 am
Baselyne
« Reply #13 on: January 19, 2008, 06:46:14 am »
Who else is everyone in the GTA doing there injectors with....
Reply #14January 19, 2008, 07:57:45 pm
Dr. Diesel
  • 1341
« Reply #14 on: January 19, 2008, 07:57:45 pm »
yeah, I don't know. But to coin a wankery little phrase, skip the rest and go to the best.
here's his contact info:
http://vwdiesel.net/phpBB/viewtopic.php?t=3100
