Author Topic: 1.6 td any years better then others?  (Read 2854 times)
January 02, 2008, 07:49:20 am
boostaholic
  • 11
« on: January 02, 2008, 07:49:20 am »
so i want to swap a TD into my N/A diesel coupe.. and i am curious any years better then others to look at for the 1.6 td? thanks
1990 jetta coupe diesel
Reply #1January 02, 2008, 12:37:57 pm
bert
  • 423
« Reply #1 on: January 02, 2008, 12:37:57 pm »
The one with the T3 on the back,JR engine code i think  :wink:
Bert
Reply #2January 02, 2008, 03:04:12 pm
  • 5104
« Reply #2 on: January 02, 2008, 03:04:12 pm »
i don't believe the engine code has much to do with what turbo it has, but i could be wrong.  the only real differences are the which turbo and whether its solid lifter or hydro lifter.
Reply #3January 02, 2008, 04:44:29 pm
boostaholic
  • 11
« Reply #3 on: January 02, 2008, 04:44:29 pm »
so a 1984 would have? solid lifters?
Reply #4January 02, 2008, 05:27:28 pm
bigblockchev
  • 271
« Reply #4 on: January 02, 2008, 05:27:28 pm »
Probably the last years of production would be the most reliable ie 91-92. The lowest mileage is good too, just so everything is not worn out. You can re-machine everything of course but it gets pricy. I find it hard to beat the stock assembly from the factory, it takes a very good diesel specialist machine shop to duplicate the reliability of a factory engine. Speaking as one who has blown up my share of engines and built quite a few. Cheers Dan
it's always something simple
one test is worth a thousand guesses
95 Chev Suburban 6.5 w performance mods
91 Mercedes 300D 603.960 6cyl 3L
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
5.5 years and counting on B100
Reply #5January 03, 2008, 07:20:20 am
« Reply #5 on: January 03, 2008, 07:20:20 am »
I'm afraid of 92 TDs in the 200-300k range because I've heard that they have bad piston rings. I've taken 2 apart to confirm this. It's just a phobia though and most are probably fine
