Author Topic: Performance question  (Read 8635 times)
Reply #15January 06, 2008, 02:17:56 am
carrizog60
  • 978
« Reply #15 on: January 06, 2008, 02:17:56 am »
glad to see that you fugured ou your problem but for have more power/smoke you just give more fuel and backed the residual screw right?
i cant back the residual screw more(i adjusted the linkage and even pushing back the idle wont go down more) but still cant have enough fuel :roll:
Portugal
Reply #16January 06, 2008, 02:00:12 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #16 on: January 06, 2008, 02:00:12 pm »
carrizog: what kind of pump do you have? Got any pics?
Don: I am fully aware of the charicteristics of the Quaife. Thats why I pointed out that the wheel spin doesnt occur anymore. Its good, but it would be nice to spin wheels in 2nd with a Quaife :D I can dream right?
I drove it again today and I would say its definitely quicker than the properly tuned 1.8 16v that I took out.
Reply #17January 06, 2008, 02:03:29 pm
carrizog60
  • 978
« Reply #17 on: January 06, 2008, 02:03:29 pm »
i have a 1.6td (JR engine code) pump...
Portugal
Reply #18January 06, 2008, 02:06:40 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #18 on: January 06, 2008, 02:06:40 pm »
can you take a pic of the top of the pump pointing out the adjustments that you made?
What are the cold start screws?
Reply #19January 06, 2008, 02:10:22 pm
carrizog60
  • 978
« Reply #19 on: January 06, 2008, 02:10:22 pm »
the ones in the back of the pump(engine side)
almost have no adjustments in no place and still cant make  boost like before...
now i only see a haze of smoke and boost tops at 1.6/1.7 bar at the best...
before i sometimes saw the needle way past 2 bar if i rev the piss out of it...
Portugal
Reply #20January 06, 2008, 02:14:48 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #20 on: January 06, 2008, 02:14:48 pm »
what specifically did you change before you noticed this problem?
Reply #21January 06, 2008, 02:51:32 pm
carrizog60
  • 978
« Reply #21 on: January 06, 2008, 02:51:32 pm »
the car went to the shop to change the headgasket(now 1.9),distribution belt,and a refresh pump from a SB.
the pump was not that fresh and in the end the old pump was put again...
tomorrow i will take a pic
Portugal
Reply #22January 07, 2008, 01:03:00 pm
carrizog60
  • 978
« Reply #22 on: January 07, 2008, 01:03:00 pm »
here are the pics from the pump and were the screws are:
the residual all way out,cant back the idle more with this screw...
the ones in the back are almost to the limit as the cold start knob almost does nothing...
the fuel screw only couple turns in,you can see the stock markings in yellow
as i said before with K24 and closed wastegate i cant pass 1.7 bar when before the pump was opened it will go way past 2 bar... :roll:
Portugal
Reply #23January 07, 2008, 08:09:13 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #23 on: January 07, 2008, 08:09:13 pm »
woodruff key aligned properly on the pump sprocket?
Cam timing set with the lock tool?
pump timing was set with the cable pushed in (warm running setup)?
double check pump timing (I had to check a few times)
Is the crank timing being checked on the flywheel ot the crank pulley?
Do you have a harmonic dampener on the crank pulley?
Reply #24January 07, 2008, 08:28:09 pm
« Reply #24 on: January 07, 2008, 08:28:09 pm »
Are your Merc nozzles calibrated to the same pressure as your old ones were? If not, that can change the timing.
Reply #25January 08, 2008, 02:04:41 am
carrizog60
  • 978
« Reply #25 on: January 08, 2008, 02:04:41 am »
Quote from: "vanagonturbo"
dont know what is that...i guesse they didnt touch anything but the t.shaft
yes
first time when come from the shop yes(was out and you couldnt push it in),went back and they put the knob in(dont know what they do tho)
yes,1.00mm
all timing marks were align recently as the shop left it a tooth off...
what is that?
yes, new nozzles calibrated to 155 bar
Portugal
Reply #26January 08, 2008, 05:08:34 pm
carrizog60
  • 978
« Reply #26 on: January 08, 2008, 05:08:34 pm »
well, after doing some search i came across this thread:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=3365&postdays=0&postorder=asc&highlight=starwheel&start=0
at the end the problem was overcome with replacing the oring in the fuel screw...
can someone explain this to me?how can a oring make all that difference?
Portugal
Reply #27January 09, 2008, 09:27:40 am
carrizog60
  • 978
« Reply #27 on: January 09, 2008, 09:27:40 am »
:idea:
Portugal
Reply #28January 09, 2008, 10:34:45 am
« Reply #28 on: January 09, 2008, 10:34:45 am »
do you have any fuel leaks/dribbles? maybe his pump was in need of replacement o-ring because of a leak.  leak = less internal pressure which = less fuel.
Reply #29January 09, 2008, 12:54:29 pm
carrizog60
  • 978
« Reply #29 on: January 09, 2008, 12:54:29 pm »
no,i see no leaks...
so why in the hell cant i lower the idle more(to add+fuel)?
as you can see my fuel screw looks like the car is underfueles as the screw is outer than with original specs... :roll:
with bloked WG i can only see 1.6/1.7 max...
Portugal
