Author Topic: temp sender/ Glow Plugs problems on 1.6 td  (Read 10615 times)
December 15, 2007, 03:53:32 pm
Gernster
  • 87
« on: December 15, 2007, 03:53:32 pm »
on my mk2 golf the temp warning light is constantly flashing and the guage doesnt read.
Can somone tell me where the sender is on the engine so I can test/ replace it? Ive just changed the clocks and it hasnt cured the problem.
There are two plugs on what looks like the thermostat housing but dont know which one is the sender!
Part B
Glow Plug led doesn't light, any ideas where to start looking?
I can hear the relay clicking iun and out and the glow plugs work because the car starts! but would like to know how long to leave the ignition before turning over.
Reply #1December 15, 2007, 04:19:12 pm
oldskool rich
  • 446
« Reply #1 on: December 15, 2007, 04:19:12 pm »
wud most lightly be 1 of the 2 senders on the plastic pipe that comes out of the front of ur head, they control ur glow plug LED and temp guage, sumtimes just cum unclipped (thermostat is next to ur water pump, wont be that)
gud luck
f6squared I.D.S.T
Reply #2December 15, 2007, 05:15:25 pm
Re: temp sender/ Glow Plugs problems on 1.6 td
« Reply #2 on: December 15, 2007, 05:15:25 pm »
Quote from: "Gernster"
around 10-15 seconds should do it.
Reply #3December 15, 2007, 05:15:37 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #3 on: December 15, 2007, 05:15:37 pm »
Wow. That was some pretty terrible spelling.  :roll:
Try checking the level sender on the coolant bottle for the flashing light problem. It sounds like you have a few things going on. Usually if the coolant temp sender for the gauge is shorted to ground, it will make the needle peg out and make the light flash. Its possible that you are low on coolant and thats why the light is flashing.
There are two senders on your engine. It depends on what year you have. If you have metal flanges then you should have either
a. two senders on the coolant flange that goes to the heater core or
b. one sender on that flange and another one that is on the upper radiator hose flange or
c. a four pin plug on the coolant flange that goes to the upper radiator hose.
Check for loose or missing wires. The colors are (IIRC) blue/ white (glow plug relay) and blue/yellow (coolant temp gauge).
HTH
Reply #4December 15, 2007, 06:48:53 pm
bmor
  • 2
« Reply #4 on: December 15, 2007, 06:48:53 pm »
on my 95 Jetta GL Turbo Diesel the dash board glow plug indicator often does not light up, often when the engins is cold this can be remedied by turning off and on the ignition. When engine is warm often not. :?
95 Jetta GL Turbo Diesel Indirect injection
Reply #5December 15, 2007, 09:20:39 pm
Vanagoner
  • 219
« Reply #5 on: December 15, 2007, 09:20:39 pm »
Quote from: vanagonturbo
Wow. That was some pretty terrible spelling.]"  :roll:
it is the written dialect of text messaging.  I am still learning it from my teenage daughter.
 I will most assuredly persist in remaining an intransigent old fogey because I compose and render complete words and sentences in pursuit of technical exactitude, and forever surrender any present or implied claim to contemporary culture in deference to my aesthetic of eloquence.
     Moreover, I predict that by 2017, the youth of generation Z will re-incorporate "lost" words from the old vocabulary, translated into their dialect.  Intransigent will become ntraZt, eloquence will be LOcunZ, and eelymosynary = eeymoZy
Howdy oldskool rich  :D
phat caddy!
p.s.- I'd check the coolant bottle switch.
Sage
Reply #6December 16, 2007, 02:36:19 am
Gernster
  • 87
« Reply #6 on: December 16, 2007, 02:36:19 am »
cheers guys, will check all those today.
BTW, I have two plugs on the top radiator hose flange as it goes into the engine.
Could it be that the plugs are on the wrong way round?  ill take some pics for you.
I'm lost without my haynes! (UK workshop manuals, but they dont do one for the 1.6 td)
Reply #7December 16, 2007, 03:32:59 am
Gernster
  • 87
« Reply #7 on: December 16, 2007, 03:32:59 am »
heres some pics:
Looks like the top sensor is blue/white - brown/white
and side one is yellow/red - brown Is this all ok? ive wd40'd the connections but no difference.
PS its stopped flashing now ive topped it up with coolant!
[/img]
Reply #8December 16, 2007, 12:53:58 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #8 on: December 16, 2007, 12:53:58 pm »
LOL @ Vanagoner :D That was highly entertaining!
Gernster, do you have a volt meter? Check resistance between the ground terminal on the battery and the brown wire at each plug. Seeing as how you are having problems with BOTH sensors, its likely that the grounds for them go to the same location and are not making a good connection.
A quick way to test the sensors themselves is to disconnect one, jumper the two terminals and check to see is the gauge pegs out or the glow plug light comes on.
The one with the blue/white should turn on the glow plug light when jumpered with the key in the on position.
The one with the yellow/red wire should peg out the coolant temp gauge and turn on the flashy light.
Reply #9December 16, 2007, 02:05:39 pm
Gernster
  • 87
« Reply #9 on: December 16, 2007, 02:05:39 pm »
cheers mate, good tip, bad earth, why didnt I think of that!
Im a fairly handy mechanic, but am new to VW's!
cheers
Andy
Reply #10December 16, 2007, 02:05:52 pm
GTD.
  • 183
    • http://tinyurl.com/6yk84
« Reply #10 on: December 16, 2007, 02:05:52 pm »
Quote from: Vanagoner
Quote from: "vanagonturbo"
phat caddy!
 :roll: Rich actually is dyslexic
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #11December 16, 2007, 02:12:09 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #11 on: December 16, 2007, 02:12:09 pm »
Dyslexia has nothing to do with choosing to spell (or not spell) the word "you" with one letter ("u").
Reply #12December 16, 2007, 02:13:23 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #12 on: December 16, 2007, 02:13:23 pm »
cheers
Andy
glad to help. I always seem to find it funny that you guys call it earth ;) at least you knew what I meant when I said ground :)
Reply #13December 17, 2007, 09:21:00 am
Gernster
  • 87
« Reply #13 on: December 17, 2007, 09:21:00 am »
given the earth & plugs a good wiggle and the temp guage is now working, but still no glow plug led? Even shorted the sensor, maybe the dash is faulty.
Does the circuit have a fuse?
Reply #14December 20, 2007, 06:15:21 pm
mk2diesel
  • 60
« Reply #14 on: December 20, 2007, 06:15:21 pm »
only fuse is  on the firewall ( metal strip)
 the relay may be bad  also ( no signal to the dash LED)
if you pull both temp sending  connectors and turn the ignition ON , the glow plugs and light should stay ON ..... remember to reconnect them after testing.
