Author Topic: IDI TDI compatability  (Read 29180 times)
Reply #15January 13, 2008, 10:13:39 pm
Helliouse
  • 164
1.6l Franken...DI?!?!?
« Reply #15 on: January 13, 2008, 10:13:39 pm »
So, let me get this right, you have a 1Z head, that is fitting on you 1.9l AAZ, and a AAZ head can fit on a 1.6l, so, this means I may have to buy a new head?
If so, what do I do with my pistons? DI pistons are far from the same as my lowly 1.6l pistions.
Please let me know as my motor is sitting in pieces right now, and have pump just about ready to head to Giles, and a 1.9l idi head to send to Dave...
1990 Jetta TD...Its a Project! And wait...its built in Wolfsberg! swEEt - 1.6l TD = Dead... TDI ALH in the works...
Reply #16January 13, 2008, 10:39:53 pm
« Reply #16 on: January 13, 2008, 10:39:53 pm »
So far, there aren't any 1.6 TDI pistons available, though Mr Prothe says he's working on it. Doing a little looking, the 1.2 TDI PD engine has the same bore and stroke, but I don't know if the pins are the same size and in the same place as on a 1.6.
Reply #17January 14, 2008, 06:09:47 am
« Reply #17 on: January 14, 2008, 06:09:47 am »
Quote from: "jimfoo"
i bet they are... or pretty damn close to it.  they really seem to beef up PD engines to withstand much more abuse than they actually receive... which make them great for tuning  :wink:
i wonder... 1.6PD?  :twisted:
Reply #18January 14, 2008, 06:53:36 am
« Reply #18 on: January 14, 2008, 06:53:36 am »
Quote from: "jtanguay"
But does a PD head fit on a 1.6 block? Looks like some one elses turn to create a new franken motor.
Reply #19January 14, 2008, 09:05:50 am
Helliouse
  • 164
« Reply #19 on: January 14, 2008, 09:05:50 am »
I am not sure how 1.2l can have the same bore and stroke, as this would make it a 1.6l, unless head volume is way, way less.
If indeed the head volume is .4l smaller then I can't see why it wouldn't be the same engine, VW is very smart, why build a different block (R&D, manufacturing) when you already have one that will work, $$ and all.
If the head volume isn't .4l smaller then either the bore or the stroke has to be different, one hopes it is the stroke!
Though this does give me some hope as to a top secret project I am working on!
And on that note, does Mr Prothe have any expected finish date, and a cost?
I will have to PM him to see…
So very promising!!
Reply #20January 14, 2008, 09:48:26 am
« Reply #20 on: January 14, 2008, 09:48:26 am »
Because a 1.2 is a 3 cylinder.
Reply #21January 14, 2008, 02:15:43 pm
« Reply #21 on: January 14, 2008, 02:15:43 pm »
interesting this thread is
Reply #22January 14, 2008, 04:18:12 pm
subsonic
  • 1836
« Reply #22 on: January 14, 2008, 04:18:12 pm »
Quote from: "Trev0rbr"
http://www.youtube.com/watch?v=IRd9PGmAQUE&feature=related
Reply #23January 14, 2008, 05:28:41 pm
Vanagoner
  • 219
« Reply #23 on: January 14, 2008, 05:28:41 pm »
Ignorant, my question is- ;)
what is a PD?
Sage
Reply #24January 14, 2008, 05:33:18 pm
« Reply #24 on: January 14, 2008, 05:33:18 pm »
A tdi engine that uses a small cam driven injection pump with one pump per cylinder. They mount in the head under the valve cover, but are electronically controlled.
Reply #25January 15, 2008, 04:26:35 am
« Reply #25 on: January 15, 2008, 04:26:35 am »
PD = Pump Duse - German for Pump Injector / Unit Injector.
Reply #26January 23, 2008, 03:32:38 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #26 on: January 23, 2008, 03:32:38 am »
there were many diesel models produced.
there was a 1.9L SDi non turbo direct injection engine. also a 1.9 IDI N/A. then theres the mechanical injection 1.9LTDi using the Bosche VE injector pump. there are few differences between the first TDi's and the AAZ - injectors, camplate, pistons.... no precups... not much more.
lots of stuff is interchangeable.... great aint it?
so the 1.6 is 76.5mm bore right? surely theres a TDI piston with that diameter.
'91 Golf Cabrio 1.9TD
Reply #27January 23, 2008, 07:18:28 am
« Reply #27 on: January 23, 2008, 07:18:28 am »
The 1.2 mentioned above. Elsewhere, someone found they cost $250 each.
Reply #28January 23, 2008, 07:19:14 am
« Reply #28 on: January 23, 2008, 07:19:14 am »
just wait for the chinese to start ripping them off  :wink:
Reply #29January 23, 2008, 07:20:10 am
« Reply #29 on: January 23, 2008, 07:20:10 am »
You going to be first in line?  :wink:
