Author Topic: water pump  (Read 9986 times)
Reply #30December 09, 2007, 09:06:21 pm
water pump
« Reply #30 on: December 09, 2007, 09:06:21 pm »
well you shouldn't drink distilled water all the time, but it is good at 'flushing' the body of toxins and mineral deposits.
Water
Water is very important for health. You should at least drink an ounce of water for each kilo (2 pounds roughly). So if you weigh 150 pounds, you should drink 75 ounces of water, which is about 2.5 liters. Please note there is a major difference in water qualities. The best water, according to Reams, is distilled water. The water should have the least amount of minerals (The Belgium Spa mineral water only has 30mg per liter). Besides the zero-mineral content, the extra advantage of distilled water is the high energy. Dr. Beddoe says that water is the "wettest" of all waters.
that is mostly because we get practically all the minerals we need from fruits and vegetables.
Reply #31December 10, 2007, 01:45:06 pm
water pump
« Reply #31 on: December 10, 2007, 01:45:06 pm »
Ok the next weird thing, I went on a hundred mile drive the other day with the radiator mostly covered, outside temp about 0F/-17c and the car was getting hotter than I like so I removed the cardboard and after 30mi and the temp didn't change at all.
Yeah, I got a 185F t-stat.
I'm using tap water, never knew why it said to use distilled.
As for the water pump not pumping good I'm getting a strong jet of coolant at the little hose that goes into the top of the bottle. When I get the time I'll flush the system with prestone flusher.
I had a cousin that drank distilled water and thought it gave her lots of energy, she could run forever.    thanks a lot. :)
Reply #32December 14, 2007, 03:11:23 pm
water pump
« Reply #32 on: December 14, 2007, 03:11:23 pm »
Well, I flushed the system and I think the heat is better, I still have to run the secondary water pump but thats not a biggy. Now the water temp doesn't go much past normal except w/ cardboard in front of the rad. I did some experiments and noticed that cardboard is not necessary to get the engine hot :shock: , it's funny how everybody says you need cardboard but I think thats kinda why there's a t-stat :idea: Also, people think diesels don't get as hot as gassers but a diesel rabbit has a bigger radiator than a gas rabbit :!: Hence, good t- stat=no cardboard needed, unless it's really cold out then it might be good to block it just to keep the cold air off of stuff.                 Thanks for all the help guys :)
