Author Topic: Stalled while driving and won't restart  (Read 7501 times)
Reply #15November 29, 2007, 08:48:32 am
« Reply #15 on: November 29, 2007, 08:48:32 am »
You can buy inline fuses, called maxi fuse, in a 50 amp rating. They have a time delay as well. That's what I'm running on my Taurus fan that has a 100A draw at startup.
Reply #16November 29, 2007, 11:11:39 am
Jetta Fan
  • 286
« Reply #16 on: November 29, 2007, 11:11:39 am »
Cool, thanks for the info Jim.
1997 Jetta 1.9TD AAZ
Reply #17November 29, 2007, 11:21:10 am
« Reply #17 on: November 29, 2007, 11:21:10 am »
IM sent
Reply #18November 30, 2007, 05:49:10 am
addautomotive
« Reply #18 on: November 30, 2007, 05:49:10 am »
update?
Reply #19November 30, 2007, 06:34:19 am
Jetta Fan
  • 286
« Reply #19 on: November 30, 2007, 06:34:19 am »
OK, worked on it bit last night..... I think I will go with the solenoid under the hood until I have time to rip into things and find out what happened to some wires, specifically the ground and the 12v to the stop solenoid.
I went to Dad's (where the car was) and we couldn't find the spare solenoid we both know he had. So, I went with the set up I described yesterday until I get some parts (solenoid, in line fuse etc). I needed the car, so had to go with a lot of juice through a switch. Cold start this morning....a few degrees above freezing. Held button in for about 12 seconds and it didn't get hot and fired right up so glow plugs are working fine.
I think I'll try to hook up a light on the dash when i do the solenoid so I know when the GPs are on. Anyone have any suggestions? I was just going to run a wire from the GP side of the solenoid to a light on the dash (or somewhere) and then to ground.
I appreciate all the help and Tyler, that e-mail will really help. Thanks.
Reply #20November 30, 2007, 07:37:55 am
« Reply #20 on: November 30, 2007, 07:37:55 am »
Reply #21November 30, 2007, 07:57:14 am
addautomotive
« Reply #21 on: November 30, 2007, 07:57:14 am »
I ran a lead off the first (easy to get at) glowplug, back to the dash. That's when I realized that the AAZ glowplugs stay on for 2 minutes!
Reply #22November 30, 2007, 03:35:06 pm
« Reply #22 on: November 30, 2007, 03:35:06 pm »
Quote from: "addautomotive"
yep they stay on a little while after the engine has been running.  to try and reduce emissions.  must really take a beating though  :lol:
