Author Topic: Hard starting after sitting for the night, rough cold idle  (Read 4734 times)
Reply #15November 30, 2007, 06:55:51 am
BejamminR
  • 89
« Reply #15 on: November 30, 2007, 06:55:51 am »
Quote from: "ilomax"
I'm sure if I keep running a high % of bio that I'll see leaks.
I ran over 10,000km on B100 last summer, no leaks and no problems. Shortly after that, the fuel filter started getting restrictive, so I replaced it with the one that I keep in the trunk for just such an occasion. As far as biodiesel's gel points:
Check out the following link for the basic performances of the vegetable oil, the methyl ester (Methanol biodiesel, most common by far) and the ethyl ester (Ethanol biodiesel, very rare). (Vegetable Oil / Biodiesel Characteristic Charts)You can fairly easily make some inferences about the performance of these when mixed with diesel #1
or #2, depending which you're using at a given time. Basically, if you're mixing 50-50, split the temperature differential between the cloud points / pour points / gel points two fuels for a reasonable guess at when you're going to be euchred if you're running on one or the other. However, the thing to bear in mind is that when you blend, you're making a mechanical combination, not a chemical mix. The upshot of that is that you don't perfectly combine the chemical characteristics of the fuel, so you could wind up with particles of frozen/gelled biodiesel in your perfectly liquid petrodiesel. Conversely, depending on the mix, you might have near-perfect combination and it's all good - just important to take those kinds of things into consideration. I run B100 as much as I can, but I do avoid it during the particularly low temperatures for the reasons mentioned here.
Glad you've got everything back up and running, and that you're loving the biodiesel!
Reply #16November 30, 2007, 09:07:15 am
ilomax
  • 86
« Reply #16 on: November 30, 2007, 09:07:15 am »
Thats for the very detailed post.
I really appreciate all the input.
2001 Audi A8L - Air Ride Suspension - Car PC - 19" Work Equipped Euroline DH - For Sale / $18,000.
1984 Rabbit - Daily driver smoke machine - Can't complain about 23 year old technology that gets 45 MPG.
Reply #17December 01, 2007, 12:00:24 pm
ilomax
  • 86
« Reply #17 on: December 01, 2007, 12:00:24 pm »
Soooo, one more update.  I hope all these updates will help people diagnose issues.
I did a scary test.  I let the car sit over night and it easily got below 40 deg. (It's actually snowing as I type this) and I didn't plug the car in.
I get in this morning after a COLD night and the first crank does nothing, just turns over...
Damn!
Second crank does nothing, the car turns over but doesn't catch.
DAMN IT!
Third crank, the little rabbit comes to life....Bwaaa haaa haaa.
So, I have 95% of the issue cured.
I'm going to take a wild guess and say that the next 5% to make it perfect will be the pump timing.
Ohh ya, and I notice a loss in MPG running Bio.
