Author Topic: differences in the ECO 1.6TD and the regular 1.6TD?  (Read 13067 times)
Reply #15November 19, 2007, 03:56:04 pm
vw_jason79
  • 7
« Reply #15 on: November 19, 2007, 03:56:04 pm »
Thanks for your help. This really helped steer me in the right direction. Unfortunately I wasnt able to get any MB injectors today at the JY.  :x
Reply #16November 20, 2007, 08:26:59 am
VelocityConservation
  • 92
« Reply #16 on: November 20, 2007, 08:26:59 am »
Don't forget that you need to create an air line from the intake to you IP aneroid to get the fueling compensation.
I have a basically stock 92' TD with a PP 2.5" downpipe and 2.25" exhaust with the k24 turbo.  I have very little lag.  It is making 2psi by 2000 rpm (holding rpm steady on a flat).  The K24 will make 5psi almost instantly when I squash the "go-pedal" and builds to where my stock wastegate opens at around 11psi.  In the current tune it makes no appreciable smoke
"Burn" I think you will be thrilled with the k24 you have when you open up the exhaust.
90 TD Jetta, NA to TD swap completed '07
Reply #17November 20, 2007, 11:45:43 am
vw_jason79
  • 7
« Reply #17 on: November 20, 2007, 11:45:43 am »
Thanks for the input. Keep the advice coming, Im all ears.  :)
