Author Topic: Non VNT on a TDI  (Read 6699 times)
November 06, 2007, 05:17:48 am
Bojje
  • 25
Non VNT on a TDI
« on: November 06, 2007, 05:17:48 am »
How's the powerband with a non VNT turbo on a TDI?
Anyone running gasser turbos? As far as I know the difference between gasser and diesel turbos is that the gasser turbos have a different choice of material because they're running on a much higher temperature than diesel turbos.
Reply #1November 06, 2007, 09:59:35 am
Non VNT on a TDI
« Reply #1 on: November 06, 2007, 09:59:35 am »
gasser turbo's make power in the upper rpm range, say 3500 rpm and beyond?  up to 7k rpm ?
diesels barely rev to 5000 rpm.  the turbo will make boost at around 1800 rpm.
i'm pretty sure diesels can get just as hot as gassers, and the only reason a gasser would get hot is from running too lean.
Reply #2November 16, 2007, 08:12:37 am
BleachedBora
  • Administrator
  • 104
    • Cascade German Parts
Re: Non VNT on a TDI
« Reply #2 on: November 16, 2007, 08:12:37 am »
Quote from: "Bojje"
Then I don't want to know how hot the gassers go--I got my K03 (non VNT wastegated) turbo to 1600 degrees quite often--although I didn't keep it there!
JT is right about the power/RPM range, to answer your question, there are hybrid turbos out there that I've had dealings with for a few years that give you extra power, MPG and torque, but on the whole there are not many real options for the wastegated crowd. As for power band, I'd pull hard from 1700 RPM to almost 5K with a hybrid turbo, 1800-4500 with a standard wastegated turbo.
-BB
'81 CBEA Caddy, '81 DeLorean, '98 Defender TDI, Too many VAG to list
www.cascadegerman.com
Sales and support: [email protected]
Reply #3November 26, 2007, 10:16:14 am
Bojje
  • 25
Non VNT on a TDI
« Reply #3 on: November 26, 2007, 10:16:14 am »
So a non VNT turbo works almost as good as an VNT - just a little more lag.
So which non VNT turbo do you guys recommend for let's say 200-220 hp on a 1,9 TDI?
Reply #4November 28, 2007, 08:29:05 pm
BleachedBora
  • Administrator
  • 104
Non VNT on a TDI
« Reply #4 on: November 28, 2007, 08:29:05 pm »
Stage III hybrid with PP764s or R520s, custom tune and downpipe and FMIC should do the trick. Let me know if I can help.
-BB
Reply #5November 30, 2007, 10:45:55 am
A2TD
Non VNT on a TDI
« Reply #5 on: November 30, 2007, 10:45:55 am »
I use a GT2056(wastegate) on my setup and it works beautifully. Alot of the mk4 guys are biased towards the VNT setups because its easier for the existing ECU in the car, to control them. FWIW Audi's running 2 GT37 wastegate turbos on their R10.
