Author Topic: Graph of cylinder pressure vs crank angle, where???  (Read 14950 times)
Reply #15October 17, 2007, 03:37:55 pm
Mark(The Miser)UK
  • 1557
« Reply #15 on: October 17, 2007, 03:37:55 pm »
xud9te  I thought the pressure was low for a diesel :o)
Greg the scale used by Mr 'Citroen engine'  reads 1 bar at zero gauge pressure; so the vaccum is present.
Now  xud... Gregs into Citroens... :lol:
Funny how Citroen diesels run cold [well at least my fathers AX does.]  Contrast with VW TD's which are designed to run at boiling point of water hence the requirement to run with antifreeze...
Mark-The-Miser-UK
Reply #16October 18, 2007, 02:17:15 am
greg123
  • 73
    • http://www.small-engine.co.uk
« Reply #16 on: October 18, 2007, 02:17:15 am »
They don't run cold, well not the tud3 (which is TOTALLY different to the XUD in every way, complete different series) the tud3 has a hot stat in it and in addition has Serious heat transfer to the water.  I once got on to boiling point with no water in it in a matter of about 90 seconds from starting (fresh head on, checking all okay before fitting rad etc) and nearly warped the head, sizzled good....
Unless the stat is sticking, they warm up VERY quick and have a notorious overheating problem though that's more to do with seepage into the coolant from head gasket issues from the wet liners moving in the 1.4 alloy block.  The 1.5 cast block doesn't heat as fast and behaves more like an XUD.  It's got a different head design with the glow plugs and injector positions reversed as well.
My xud warms up to feel heat from the heater by the end of 2 local roads and is hot on the gauge within 10 mins (fully up to temp) which I think is reasonable.  The tdi engines run COOLER and have a lot of trouble warming up if you just let them idle.  All tdi engines by nature will run cooler as they have less heat transfer to the head and less friction in/out of the pre-chamber, it's why they are more economic.  Energy is lost to heat in a IDI more than a TDI.  The runner temperature is governed by thermostat choice and I just changed two on a TDI which as I recall were only 87 degree ones, nothing specially hot.  The gauge can be misleading.
Modern tdi's run so cold unless under power that in gentle driving they won't warm up, so they have to have a diesel fired heater fitted to heat the car!  Some of the new pug 1.4's have that as I recall.
I'll study the graphs more later, interesting!
Freelance Mechanic specialising in Tdi motors and Veg-oil 2-tank conversions.
Reply #17October 18, 2007, 03:18:13 am
xud9te
  • 88
« Reply #17 on: October 18, 2007, 03:18:13 am »
Hi Greg,
Another PSA diesel sufferer!  My ZX (my brothers zx now  :( ) runs at 80 dead on most of the time, and will creep up to 90 if you are at full speed ahead for a while (135mph on the clock!) or if you are giving it some b road abuse.
The cooling systems are sh*te on these cars though I agree.  Its THE reason why they need a head gasket at 100k without fail.  Then if you dont change the radiator, it goes again because thats what the problem was!  Also those stupid bayonet fitting hoses at the bottom of the rad that are about 3mm ID?!!!
Mr the miser, are you sure the ax has got a thermostat in it at all? :lol:
If you want the spreadsheet Greg, I can email you it if you like.  As Mr The Miser syas correctly, the pressure scale is absolute, i.e. atmospheric pressure is 1 bar already.  Anything under 1 bar is a negative pressure with respect to atmos.
Cheers
greg
