Author Topic: 12mm head, came plate, 8V manifold, etc...  (Read 7853 times)
Reply #15October 07, 2007, 01:06:02 pm
Tintin
  • 1279
« Reply #15 on: October 07, 2007, 01:06:02 pm »
IDI bosch injector 175Bar 1 stage with lift sensor, It's from 1.9L Turbo IDI citroen, that work well without lift sensor, but It's perfect for a IDI electronic projet,   75$
I found a used bosch 11mm head in my disorder parts **** sold ****
VW 8valve manifold T3 flange, I bough and modified to clear intake bolt, but it not fit with my quattro tranny, not enough space for the turbo.
*****SOLD*****
mechanic/electronic citroen pump with 20mm axle and proper alignment for TDI/IDI VW 4 cyl engine, no need to connect the timing control valve, 0-volt on the sensor is the same thing that the standard VE pump,  exept that it's a good base pump for IDI/TDI hybrid mechanic/electronic control.
150$
Combo pump + injector 200$
Reply #16October 07, 2007, 05:55:17 pm
RabbitGTDguy
  • 1274
« Reply #16 on: October 07, 2007, 05:55:17 pm »
Martin, Sent you a PM on the 11mm pump head and possibly that pump base. Maybe the exhaust manifold as well as I need some of these items for the b3 mTDI build...
Joe
1972 VW Westfalia
Reply #17October 11, 2007, 02:27:30 pm
Tintin
  • 1279
« Reply #17 on: October 11, 2007, 02:27:30 pm »
up
Reply #18October 31, 2007, 08:56:10 pm
blkboostedtruck
  • 1535
« Reply #18 on: October 31, 2007, 08:56:10 pm »
PM sent for 10mm and 12mm pump head and AAZ cam plate!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
