Author Topic: aaz into a mk1 cabrio build  (Read 74039 times)
Reply #105October 28, 2008, 06:06:57 pm
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #105 on: October 28, 2008, 06:06:57 pm »
That exhaust turn down works perfectly!  :D
Reply #106March 29, 2009, 11:22:41 am
giulianot
  • 146
« Reply #106 on: March 29, 2009, 11:22:41 am »
Heya All, Today I finally got a chance to  dyno my 1.9 TD cabby! In its stock form the aaz motor make 75 hp and 90lb/tq, this is what my cabby put down :D  :D
The pulls were done in 4th gear and my boost would peak at 21psi@ 3200rpm and then taper to 15psi after that :rolleyes:  not bad for a tired garret t3. The engine definitely has more potential in my opinion and would produce much more with a healthier , smaller turbo.  :P Judging By how I totally fumigated the shop, the fueling is definitely there now i just got to get a good turbo in!
I out torqued a stock vr6 it made 150 hp and 146tq
A special thanks to Giles for building me the best pump in the world!, and To Brison thanks for the constant motivation!
1990 cabriolet 1.9 aaz, kkk 24/26,  Giles pump, big  2.5" intercooler,  3 " P.P. downpipe
Reply #107April 06, 2009, 07:57:04 am
13ad13oy
  • 8
« Reply #107 on: April 06, 2009, 07:57:04 am »
Thats Sweet!
Which turbo do you have in mind? K14?
89 Caddy Truck
Reply #108April 07, 2009, 05:21:01 am
Baixo
« Reply #108 on: April 07, 2009, 05:21:01 am »
dont go T2, there are many in Europe that have successfully ran a k24 on the AAZ.
you just have a lazy turbo.....and your IC piping is a big diameter so that will affect the laggyness
I think you should show everybody how its done and get a gt28rs or a vnt22
it would be a shame to have such a nice set-up and run alittle wimpy T2
Reply #109April 07, 2009, 09:41:39 am
« Reply #109 on: April 07, 2009, 09:41:39 am »
I think a T2 or a K14 pushing 20psi would be ideal.
Reply #110April 07, 2009, 02:03:35 pm
giulianot
  • 146
« Reply #110 on: April 07, 2009, 02:03:35 pm »
I was initially content with the base line dyno #'s, but now Im just craving move. :evil:  A very good friend of mine has generously offered to let me try his k24/k26 hybrid with only 500 kms use. So upward and onwards  I have to space the exhaust manifold off the head for the turbo housing to clear. Need to get some 1/4x3"x12" precision machined flat stock to make some exhaust manifold spacers. Not even 1000kms on the motor and I'm all ready swaping the turbo :lol:
Reply #111April 07, 2009, 03:43:29 pm
Baixo
« Reply #111 on: April 07, 2009, 03:43:29 pm »
i dont think a k14 or t2 will will be efficient at 20+psi
Reply #112April 25, 2009, 08:11:39 am
giulianot
  • 146
« Reply #112 on: April 25, 2009, 08:11:39 am »
So I bought some M8 1.25  threaded rod in Stainless Steel from fastenall for $14 and cut it up in 2.5" sections .5" longer than the stock exhaust studs. I had my little brother "The Machinist" make me four  1/4" exhaust manifold spacers and the turned out really well. Now i have everything ready to make that monster k24/26 housing clear my intake manifold.
and finally some pics our future 24 hours of lemons  car??:twisted:  :P
Reply #113May 08, 2009, 05:51:46 am
giulianot
  • 146
« Reply #113 on: May 08, 2009, 05:51:46 am »
So I finally got my turbo upgrade from Bryson and it is beautiful.  :)  A little history on this turbo, It was born a k24 and was bored out to fit a k26 impellers and shaft, within a k24 housing. Hence a hybrid turbo. This was all done at a professional turbo re builder  before I owned it. Without further delay some pics.
the swap begins !! the car with the old t3 in
3" SS downpipe removed
next I removed the 4 12point 12mm bolts that hold the turbo on
and the old t3 on the floor  :P
now to remove the exhaust manifold
and now remove exhaust studs cause there gonna be to short now
and now the new longer SS studs installed
next i installed the double gasket and the manifold spacers
now to prep the turbo , Im putting a plug where the wastegate takes its pressure from the turbo, and going right to the intake manifold for wastegate  reference.
then i mounted the oil return line and installed the manifold and turbo
The new turbo spools quicker than the old t3 and will sustain 25 psi of boost.
the car is alot more powerful now and i cant wait till may 30th when i will hit the dyno again and see what kind of numbers this setup will put down.
« Last Edit: May 26, 2009, 04:44:37 pm by giulianot »
Reply #114May 08, 2009, 06:41:03 am
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #114 on: May 08, 2009, 06:41:03 am »
And then, we start feeding some REAL boost to it!  :twisted:
Reply #115May 08, 2009, 06:54:55 am
stewardc
« Reply #115 on: May 08, 2009, 06:54:55 am »
I'm interested to see how fast it will spool up. My Garrett T3 is great, but I'd like the higher boost to come in at lower RPMs.
Reply #116May 08, 2009, 09:21:37 am
TurboJ
  • 661
« Reply #116 on: May 08, 2009, 09:21:37 am »
Interesting stuff.
I'm looking forward to the new dyno numbers!
That's a nice turbo BTW! I always thought the KKKs work better than the Garretts, for some reason.
Jetta II 1.6 TD 'Project 200'
Reply #117May 21, 2009, 08:48:07 pm
  • 5104
Re: aaz into a mk1 cabrio build
« Reply #117 on: May 21, 2009, 08:48:07 pm »
aaz's are sweet.
Reply #118May 23, 2009, 12:36:48 pm
Jay
  • 157
    Derv power !
    • TONA Valet & Detailing
« Reply #118 on: May 23, 2009, 12:36:48 pm »
Very nice project here 8)
Can't wait to see what it's running now on the dyno.
Reply #119May 27, 2009, 07:26:41 pm
giulianot
  • 146
« Reply #119 on: May 27, 2009, 07:26:41 pm »
SO I needed a new plate sticker for the cabby, and that meant another "Joke" ontario emissions test. I decided to bring it to the vw dealer in orangeville since it a flat rate anywhere $36. I book an appointment with the service dept and let them know its a diesel. (Diesel emissions test in ontario is a VISUAL inspection so long as the exhaust is intact and there is no visible smoke @ idle, it's a pass)  I arrive to the dealer with the cabby and the guy at the service desk ask me for Make and model of vehicle. I tell him it's a 1990 vw cabriolet 1.9td. He says "Impossible".  He walks out to the lot and looks under the hood then says "OH we'll have to test this under hotrod/ swap class " . Ok whatever  I tell him my ownership say Power/D so it is registered as a diesel at the ministry of transportation. FINALLY he agrees to send a mechanic to preform the diesel emissions test. The VW mechanic (nice guy)  started my car in the lot and popped the hood, poked around, looked at the tailpipe @ idle, then turned to me and said "you pass". COOOl :)   So then he asks "off the record, how much fuel is this Injector pump really pushing" and I said "It's a Giles pump". "AHHH  enough said".  ;D  Now all is great I have a valid emisions and valid stickers and I'm all set to lay down some new #'s this  Saturday  at the Diesel Doctor Dyno day.  ONLY  2 more days :)
