Author Topic: glowplug light flickering and staying on after start driving  (Read 7142 times)
February 26, 2005, 09:55:14 am
sethyboy85
  • 284
« on: February 26, 2005, 09:55:14 am »
did a search cannot find anything, when I start to drive my car the glowplug light flickers and sometimes even stays on but then will go off on it's own.
no relation to it (I think) I broke my ebrake today so now the light stays on all the time although it is not engaged.
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #1March 01, 2005, 09:53:13 pm
chrissev
  • 694
Re: glowplug light flickering and staying on after start dri
« Reply #1 on: March 01, 2005, 09:53:13 pm »
Quote from: "sethyboy85"
It is the horn relay.  Don't ask me why.  It has nothing to do with the glow plugs.  They are off.  Test them to make sure, but I think you will find that they are off.  Listen for the "click" of the glowplug relay after you glow the engine and you will know they are off.
Reply #2March 02, 2005, 03:29:20 pm
Patrick
  • 1034
« Reply #2 on: March 02, 2005, 03:29:20 pm »
There's a good chance there's water in the fuel. Some of these cars have a sending unit in the separator (under the car on the passenger side at the back) hooked to the glow plug light to tell you there's a problem. Try draining the separator!
Reply #3March 03, 2005, 07:00:18 am
Hammy
  • 169
« Reply #3 on: March 03, 2005, 07:00:18 am »
Good call Patrick, I had exactly the same problem on my '85 Golf. Drained the water seperator, no more glow plug light problems. I have also heard of the situation chrissev mentioned, but for sake of ease, and really it's maintenance, I would drain the water from the separator. It's located in front of the tank, you will see it if you look underneath infront of the right rear wheel. Make sure to drain it in a suitable place. :)
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
Reply #4March 03, 2005, 02:48:29 pm
Patrick
  • 1034
« Reply #4 on: March 03, 2005, 02:48:29 pm »
Just noticed he's driving an 84. Does he have the separator?
Reply #5March 03, 2005, 02:51:34 pm
Hammy
  • 169
« Reply #5 on: March 03, 2005, 02:51:34 pm »
I was under the impression that they all had them. Never seen one without.
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
Reply #6March 04, 2005, 02:31:11 pm
sethyboy85
  • 284
« Reply #6 on: March 04, 2005, 02:31:11 pm »
nope, only have one on the factory fuel filter that is not in use... goes from fuel tank 6" of rubber line to factory steel line, rubber line, filter (not factory) fuel pump.
Reply #7March 05, 2005, 08:17:47 pm
  • 2931
glow plug flicker
« Reply #7 on: March 05, 2005, 08:17:47 pm »
The only time I've had a flickering glow plug light on an A1 was when a wire on the positive battery terminal wasn't connected well.
