Author Topic: Clutch pedal resistance question  (Read 11481 times)
Reply #30October 25, 2007, 06:46:52 pm
clbanman
  • 705
    Cambridge, Ontario
« Reply #30 on: October 25, 2007, 06:46:52 pm »
Mine's officially parked for now.  I just bought a 91 Golf 1.6NA to replace it. (Cost me $150 more than the repair estimate.)  I'll probably tear into it in the spring/summer.  The car drives fine, and I can get all gears if I don't use the clutch.  No noises while shifting, so I can't see the synchros being gone.  Manual clutch cable (new) is adjusted all the way out (only about 1/2" onto the threads).  No fractures on release arm, throwout bearing is good, internal lever looks good, acutator rod with no damage visible on the end as I would expect if it had pushed through the plate.  Starting the car in 1st gear with clutch pedal to the floor will actually move the car a bit, same with 2nd.  Clutch pedal all the way to the floor, move shifter from neutral to reverse and I can get the gear, but it grinds.  No clutch slipping when using Bentley check method.  I tried spacers between the clutch release lever and the end of the cable to effectively shorten it up with no difference.  Something in the clutch area must be broken because even with the pedal all the way in, it's still making enough contact with the flywheel to make it hard or impossible to get 1st or 2nd from neutral with the engine running.  Problem is worse when everything gets hotter.  If the car sits overnight, it works reasonably well until it gets to operating temperature.  It's a shame, because on my last tank, I got 1026 km.
Calvin
Calvin
91 VW Golf 1.6NA 5spd
Reply #31October 26, 2007, 02:37:53 pm
« Reply #31 on: October 26, 2007, 02:37:53 pm »
thats awesome mileage!  too bad :(  my car is about 700km, but i do drive pretty hard and there might be a sticky injector.
i think i've done some permanent damage to my car from the clutch possibly not engaging all the way (and driving it like that).  i've made about 2-3 trips like that, and there was no signs of clutch slip, but there can still be damage right?  to the thrust bearings?
just seems like there's some new noises... low rpm grumbles...  :cry:  drives exactly like before, except me trying to get used to the new clutch engaging point.
