Author Topic: TD tachometer?  (Read 3151 times)
September 14, 2007, 04:07:01 am
haybayian
  • 155
TD tachometer?
« on: September 14, 2007, 04:07:01 am »
Could someone offer tips on how to go about a tachometer and where to buy the hardware,preferably in Canada.
Thanks.
Haybayian
Keep it simple if you can.
Reply #1September 14, 2007, 08:21:39 pm
g-spec
  • 289
TD tachometer?
« Reply #1 on: September 14, 2007, 08:21:39 pm »
Are you looking for a tach for a mkIII or a mkII....if your looking for mkIII I have a guage cluster with a rpm guage.
p.s. Im located in london ontario
Reply #2September 14, 2007, 08:42:30 pm
TD tachometer?
« Reply #2 on: September 14, 2007, 08:42:30 pm »
Or if you're looking for one in its own pod VDO sell a version that are diesel-compatable...
http://usa.siemensvdo.com/products_solutions/cars/performance-instruments/vdo-performance-instruments/instrument-series/cockpit/tachometers/tachometers+-cockpit.htm
Either way you'll want to ensure your alternator has a terminal labeled "W"... this is where a diesel tach connects.
Reply #3September 15, 2007, 04:16:33 am
haybayian
  • 155
TD tachometer?
« Reply #3 on: September 15, 2007, 04:16:33 am »
Quote from: "g-spec"
Thanks,
I am not clear precisely what I am looking for. I am putting together a VW (AAZ) powered kitcar from a long block and I belive that my best option is a magnetic sensor. I may have to buy the VW "W" alternator as sugggested here.
Haybayian
Reply #4September 15, 2007, 06:49:11 am
TD tachometer?
« Reply #4 on: September 15, 2007, 06:49:11 am »
You can also just take an alternator apart and hook a wire to it on any phase just before it goes to the diodes. On a Delco alt, it is a stud with a bolt, so is very easy to do, but I'm not sure about a Bosch.
Reply #5September 15, 2007, 02:10:17 pm
Hillshy
  • 103
    • http://www.hillshy.co.uk
TD tachometer?
« Reply #5 on: September 15, 2007, 02:10:17 pm »
in a bosch its a spade marked "W"
the parts involved are just cheap electronic components + the actual gauge itself, unless you have one in mind?
do a search as there's lots of info here an the subject of tac's, there is also a circuit that can be built and a method to calibrate.
the bones of it:
build the circuit from the diagrams on this site, its powered by 12v source then 2 wires go into the tac and its calibrated. i had to do this and it works a treat!
have you actually got a tac on mind that you would like to use,
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
