Compressor Surge, good or bad?
Topic: Compressor Surge, good or bad? (Read 8921 times)
September 03, 2007, 11:03:55 am
zagarus
September 03, 2007, 11:03:55 am »
alright, first off watch this video and listen to the sound when shifting:
http://s76.photobucket.com/albums/j11/g60ing/?action=view¤t=174.flv
Now who can tell me if thats bad for the turbo or ok? I have been hearing mixed opinions on compressor surge in a diesel and i want to know if i should be doing something to eliminate it or if it is ok to continue driving around like that.
Project 1.9TD Jetta Coupe Completed. Back in action!
September 03, 2007, 12:21:10 pm
September 03, 2007, 12:21:10 pm »
sounds okay to me. its probably the larger DP you have that is making the turbo more audible. my turbo sounds the same, and i've pegged 20 psi no problems.
there is a little bit of white smoke, but thats ok for an old tired engine. btw nice peppy ride man!!!
September 03, 2007, 12:49:53 pm
blkboostedtruck
September 03, 2007, 12:49:53 pm »
I wish mine sound like that! my td is sounds softer than that! Is yours a GTD motor? and have you checked your shaft play lately? almost sounds like a slite impellor contact with housing? but otherwise looks and takes off quick from what i can tell in the video!
thanks Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
September 03, 2007, 12:52:24 pm
foxracer1
Authorized Vendor
September 03, 2007, 12:52:24 pm »
Thats not surge thats just the turbo slowing down. Due to boost still present on the comperssor but lack of exhaust pressure on the turbine. Just sounds sweet to me. How many PSI was that?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
September 03, 2007, 12:56:31 pm
Mark(The Miser)UK
September 03, 2007, 12:56:31 pm »
Certainly drives well or was that a speeded up camera :shock:
First Quantum TD I ever test drove had a whistling turbo on tickover/slow driving t othe point that I had to keep the windows shut... Never bought it; but the second one I tried had a 'sexy' warble on acceleration;bought it and it gave 52mpg [US]. Only not driving it because I took it off the road for a respray; and then bought 2 more with road tax on etc... It's awaiting my call patiently in a large dry barn :lol:
Mark-The-Miser-UK
September 03, 2007, 01:56:30 pm
zagarus
September 03, 2007, 01:56:30 pm »
so thats not killing me turbo? well good to know. No the engine is just a basic 1.6TD but with the AAZ nozzles, intercooled, 24psi with a garrett T3, 2.5 inch straight pipe exhaust with DP. Recaro interior and some other goodies. I think its finally worthy of a Jetta GTD badge
September 03, 2007, 01:58:58 pm
zagarus
September 03, 2007, 01:58:58 pm »
might as well throw this one in here too
http://s76.photobucket.com/albums/j11/g60ing/?action=view¤t=175.flv
September 03, 2007, 02:17:28 pm
blkboostedtruck
September 03, 2007, 02:17:28 pm »
well I will deem you worthy of GTD badge go ahead ! got an extra one for me and my pickup?L.O.L.
thanks Duane
'66 variant 1500S
September 03, 2007, 02:30:15 pm
numbnuts
September 03, 2007, 02:30:15 pm »
It does sound cool :lol:
September 03, 2007, 02:30:33 pm
zagarus
September 03, 2007, 02:30:33 pm »
if it were a Jetta then ya goto tmtuning.com, thats where i got my badge. Im sure if you sent them an email they could possibly come up with some other euro parts. Maybe even a CADDY GTD badge
that would be badass, or just make yer own.
September 03, 2007, 04:17:07 pm
Black Smokin' Diesel
September 03, 2007, 04:17:07 pm »
Haha I love the sound of the engine
Very unique and different from any turbo gasser I've heard.
Since we're posting vids...
91 Passat syncro 1.8T swapped.
Reply #11
September 03, 2007, 07:42:48 pm
bigblockchev
Reply #11 on:
September 03, 2007, 07:42:48 pm »
Does anyone have compressor maps for the various VW turbos. You can tell if the turbo is surging just by looking at the pressure ratio ( absolute pressure) and the engine rpm which will give the flow. If the point is outside the efficiency boundary then the turbo is surging. The vibration caused by the surge pulses is hard on the bearings causing wear sooner or later. Cheers Dan
it's always something simple
one test is worth a thousand guesses
95 Chev Suburban 6.5 w performance mods
91 Mercedes 300D 603.960 6cyl 3L
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan MDJF 15Kw genset
5.5 years and counting on B100
Reply #12
September 03, 2007, 07:45:51 pm
Reply #12 on:
September 03, 2007, 07:45:51 pm »
I think there are a bunch of maps in the FAQ section
Reply #13
September 03, 2007, 08:02:50 pm
bigblockchev
Reply #13 on:
September 03, 2007, 08:02:50 pm »
So Zagarus what is your rpm, boost , and engine size , also what turbo do you have. We can figure it out from there provided that the map is available. Cheers Dan
2000 Jetta TDI
Reply #14
September 03, 2007, 08:14:43 pm
Reply #14 on:
September 03, 2007, 08:14:43 pm »
Here are the garret maps
right here
